Author Topic: Charging a cell like a capacitor  (Read 1608 times)
« on: February 02, 2020, 09:16:42 am »
I got some low level results last week.
I have found sime time to play with back emf charging.
I pulsed the positive into a primairy 230v MOT coil and catched the bemf into a capacitor.
Hundreds of volts i got.
So i hooked up 1 cell and i got low level gas production.
But now the facts.
I pulsed 2 volts and 0.02mA in the coil.
And i measured 2.6v across the cell.....
Wierd.
Re: Charging a cell like a capacitor
« Reply #1 on: February 03, 2020, 11:41:17 am »
« Reply #2 on: February 03, 2020, 11:42:06 am »
its funny to see that 1.5v can charge one cell up to 2.6v...
update : Charging a cell like a capacitor
« Reply #3 on: February 21, 2020, 09:39:38 am »
Hi dear members,
Here an update on my tiny tests on the charging with help of Back emf.
I have tested Joulethiefs, Bedini types, and Imhotep based setups, last weeks.
A thanks to Okki Moeljadi for sharing some info with me on youtube about his coil setup of his radiant charger.
The guy is doing nice things over there.
I bought 5 small 12v 1.2ah battery's for the tests, together with some Diodes UF5408 and some fast switching transistors, neon bulbs, etc etc.
The idea was to create Back emf spikes for charging 4 battery's with on battery. Thats what the documents where promising. The deal is of course, to get this BEMF spike with as low as possible consumed power.
It was an interesting journey.
The schematics of Patrick Kelly are working till some extent. But they do not really charge the battery's full.
And when i hooked up the wfc for a change and to see what it would do, i didnt got more then 3 volts acros the cell with some gas production.
So, yes. I still hook up waterfuelcells to whatever i build.
So where i stand today with my testing.
Things i learned:
use bifilar air coils
Dont make them too small, but also not too big.
Use UF diodes and transistors.
And let some of the learned knowledge from technical university go.....
I was hoping to notice that thing everybody is talking about. Free energy from space...ether, Radiant energy or what ever you want to call it. Pulsing coils,  spark gaps, or whatever is needed to open the gate and to pull energy in the pulsing system.
So, i found something very interesting, yesterday. The current circuit is a sort spin of bedini and joulethief and all the earlier named systems.
The transistor is hooked up to a bifilar coil and i collect the BEMF energy and what more type of energy is coming from it.
Why am i saying that? I believe that my normal measurement tools do not registrate everything that is going on here.
Let me give you some numbers:
11V and 100mA = 1.1watts
And that amount of almost nothing is charging now my 5 battery's like crazy.......
I do have to repeate some tests the coming days, but it is very strange to witness this. The charge is also staying in the battery's, so no fake charges.
The batterys are connected now in parallel...........Not in series.
So, more tests and of course i will hook up some waterfuelcells to it later as well.
Hope this inspires you guys...
cheers!
Ps. A video will follow
« Reply #4 on: February 29, 2020, 09:50:44 am »
My test results with the back emf charger.
I discharged the battery with a current of 0.15a continue.
After a totall discharge, i charged the battery with the same consumed current.
Discharge time and charge time are equal.
No overunity here, sofar.
Water capacitor characteristics vs a normal capacitor
« Reply #5 on: June 12, 2020, 11:54:31 am »
Dear college,s,
You all are familiar with charging a normal capacitor.
Most of you, are also trying to apply the same technology on a watercapacitor.
Trying to replicate Stan Meyer.
What is a waterfuelcell for an animal? Is it a resistor? Is it a capacitor? Is it a coil? Is it a mix?
Some weeks ago, i posted a video called Strange fenomenon. I showed you a demonstration of a very basic wfc setup.
A dc powersupply, a pwm and a small multicell wfc.
I tried to observe the behaviour of the wfc with different frequencys.
In the video you see me applying 3hz pulses from 5v.
If you look good, you can extract the exact properties of my wfc.
1. First 4 seconds the wfc start charging in an opposite way as a normal capacitor is doing. From low current to max current.
2. The next 6 seconds the wfc acts as a normal capacitor. The charge current tops off the capacitor and then stops flowing after voltage level has been reached. 4 seconds of topping off and them 2 second no flowing charge.
3. After these 6 seconds, the charge is gone
4. The cycle starts again from 1.
Forgive my poor drawing abilities, but here are my notes.
Do you the same patern?
My pwm pulses at 3 hz, meaning it uses 12 pulses to open up the wfc. Then 12 pulses to dump more charge in there and then you see 2 seconds a charge stop. No current flows whatsoever........
« Reply #6 on: June 12, 2020, 12:20:03 pm »
So whats next?
After the cell is topped of and no current flows for two seconds, it is clear that the wfc leaks his current into to water. Hho is created.
I think Stan tried to extract that charge together with some freed electrons from the water before the charge flowed strait thru the wfc....
« Reply #7 on: June 18, 2020, 20:25:39 pm »
This 2 till 3 seconds has to do with flipping the protons accoording to Puharich.
This will make the bonds weak and as such, easier ro break. It will rotate the magnetic nucleus of the protons.
