Author Topic: Your Design  (Read 16082 times)
Your Design
« on: May 16, 2008, 20:30:00 pm »
Please Post your Design here, Share it with the world.
  • OO-Rah!
Re: Your Design
« Reply #1 on: May 18, 2008, 10:20:08 am »
My cell is styled after Karebills. It's a six cell. Three 316L tubes each, 1" x 10", 3/4" x 9 1/2", And 1/2" x 12". With a 1mm gap between each of the tubes. The over all size of the cell is 2" x 12" x 16".  It will be supplied water by a live well pump, as suggested.
Spike
Re: Your Design
« Reply #2 on: May 18, 2008, 10:32:26 am »
Spike
Looking good, Spike!
Br
target
Re: Your Design
« Reply #3 on: May 18, 2008, 20:07:20 pm »
plate cell that i have been working on,larger negative plates
  • OO-Rah!
Re: Your Design
« Reply #4 on: May 19, 2008, 01:13:51 am »
h2opower
 ;D It's a deal  ;D
Mine should be working tomorrow, I'll try for tuesday.
Spike
target
Re: Your Design
« Reply #5 on: May 19, 2008, 01:39:15 am »
a small tube cell  not my design borrowed some ideas ,in plain tap water 12 v   4amps about 6 inches long but only 4 inches of surface,125 ml per minute      http://www.youtube.com/watch?v=KplfdV_s4yQ
  • OO-Rah!
Re: Your Design
« Reply #6 on: May 20, 2008, 04:58:10 am »
h2opower
Karebill cell video, first run.
Here is your video
http://youtube.com/user/bulldogge1232000
Spike
  • Pochin Hydrogen
  • Hydrogen to Drive
    • PochinTwin Hydrogen
Re: Your Design
« Reply #7 on: May 23, 2008, 17:11:37 pm »
Hello
I have a question how is everybody measuring there devices in relation with the volts and the amps for example input amp and volts, output amps and volts if you have and idea
If you see the measuring of volts OPT A is connected before the FET it give you a reading and OPT B is connected after the FET witch one is correct if you have any idea?
