Author Topic: Coils mass amps restriction and applying e fields  (Read 12955 times)
« Reply #16 on: August 31, 2019, 01:21:09 am »
I like the idea of changing the waters properties to meet the circuits needs...like reaching a certain temperature.
« Reply #17 on: September 02, 2019, 22:44:26 pm »
this is certainly the best way to go! to change circuit parameters is much harder.
im thinking on how will diodes behave under such low potential situation more about negative resistance...
why faraday didn't discovered the polarisation process
« Reply #19 on: September 03, 2019, 01:56:04 am »
Stan says faraday didn't had stainless steed and modern inventions to discover the electrical polarization process but he had almost everything he needed except of that.
https://www.youtube.com/watch?v=TCi3v8QWK6M
Magnetic gas
« Reply #20 on: September 03, 2019, 03:02:21 am »
if we had a magnetizable gas inside a tube there would be a possibility to use sound resonance inside the tube to produce a kind of motion of this gas that would be able to be transformed into electricity.
I think that having sound resonance could generate emf because the gas displace will be increased amplitude...
depending on the modes of the resonance you may have the position of the coils at the tube...
perhaps the gas is going to get cold if we extract energy of it...
but an analogous system could be try with a speaker and a resonant cavity perhaps a 1 meter piece of tube with a coil to magnetize the gas and coils to measure the output of energy caused by the speaker moving the magnetised particles...
perhaps an spray of iron oxide can be used. like if it was sand you know?
question a continuos stream of iron oxide magnetised by a coil having another coil around would have emf?
« Last Edit: September 03, 2019, 03:32:14 am by sebosfato »
last posts were about epg
« Reply #21 on: September 03, 2019, 03:33:00 am »
maybe someone could do an experiment with those vacuum that aspirate water in a closed loop...
something tells me that above a certain pressure difference the magnetic particles can reach very high speed
creating a chamber for the water to splash and with a small tube is possible to make this!
perhaps the epg was using freon or some other like butane and maybe a phase change like with a refrigeration cycle.. absorbing energy from ambient and transforming to electricity by the difference pressure causing a increased speed of the particles..
water fuel cell
« Reply #22 on: September 03, 2019, 04:04:46 am »
why is it called water fuel cell
stan said the water is the source of the electrons..
water fuel cell stands for like a Duracell something that has the ability to provide electricity
from what i understood each cell will develop a higher voltage at resonance with a coil driving it at low voltage so if we put this cells in series there should be addition and cancellation of phases as different frequency is assumed...
this means two things, the first is that if the cell has a charge and another cell also has a charge and you connect both in series the voltage will double when phase coherent, and this will allow the cells to discharge into one another if the circuit is closed... i could be wrong but im seeing each cell separately... but for make sure i see all sides i also imagined one thing
if the 11 cell cavity had one smalll coil or perhaps one turn coil per cell a bigger coil could oscillate the whole system being around the whole cell. this would make phase coherent so would make sense to connect the cells with a canceling phase and apply 1v to see what happen.... im thinking that perhaps connecting the cells to each other thru a diode and choke may be all that is needed to take advantage of the water fuel cell potential...
if what im saying is correct it would explain why  meyer had a vic for each cell
it would explain why he said the system is a short circuit
it would explain why his prototype electrical shield the outer electrode..
he certainly mislead us but he left behind also some true
we need to identify where is it
if we connect the cells by the inside electrode they will have equipotential while the outer electrodes being shield can be positive of negative
stan said that even the slightest voltage difference would cause ionic movement.
Re: last posts were about epg
« Reply #23 on: September 03, 2019, 14:06:11 pm »
I just got a brainwave..
The epg has a pump build in, is it.
If the ferrofluid is just pumped around, you should not really experience a change in the magnetic field.
But what if the pump is quickly going forward and backwards......
