Author Topic: Stanley A Meyer Spherical Resonant Cavity Replication  (Read 403 times)
« Last Edit: March 12, 2021, 20:55:29 pm by jim miller »
Re: Stan Meyer Spherical Resononant Cavity Replication
« Reply #1 on: March 05, 2019, 06:04:42 am »
Thanks for sharing... here's two others people should find interesting.
« Last Edit: March 05, 2019, 23:49:00 pm by Adriank »
  • Build it. Power it. Use it.
« Reply #2 on: March 07, 2019, 19:42:25 pm »
Using Stan's statement that the resonant cavity operated at the "extremely low potential of 48 Volts", I was able to determine the resonant frequency.  I set my Vernier calipers to 48 mm, then adjusted the screen size so the potential side of the resonance diagram matched.  Then I measured the pulse rate side and it's 24 mm.  So the resonant frequency, for his cavity, was 24 pulses per second.  This two-to-one ratio doesn't hold for other voltages, due to the geometric relationship, but a similar method can be used to determine the ration at some other specific voltage.
