Author Topic: series LC resonance in a DC circuit  (Read 1954 times)
« on: December 28, 2018, 17:06:32 pm »
Dear all,
Just to make a point:
Do you know what happens if you add a coil in series with a capacitor?
I hope you say: it doubles the voltage across the capacitor...
Now try to do that with a watercell........
Re: series LC resonance in a DC circuit
« Reply #2 on: December 29, 2018, 00:07:09 am »
Yes bro thats what im trying to tell you
« Reply #3 on: December 29, 2018, 01:26:50 am »
Adding electrolyte would raise the dielectric constant.... I was thinking perhaps is good to have a composite electrolyte having a salt and a base or acid... This way there is going to be more ions of both types
« Reply #4 on: December 29, 2018, 01:40:10 am »
I tried this and noway i found any raise in voltage across the cell....
Not sure if extra electrolyte will help, Fabio.
It is confusing...
« Reply #5 on: December 29, 2018, 02:21:47 am »
perhaps you should use a low voltage like 0,5v
« Reply #6 on: December 29, 2018, 15:29:01 pm »
This is a misunderstanding.
The way you get the double of voltage if when a real capacitor fully charges to voltage supplied and there will be no current flow anymore, so the inductor collapses producing the pulse BUT THE POWER SUPPLY IS STILL CONNECTED, and since that, it charges to Vsupplied + inductor pulse in series.
In a pulsed system as Meyer with non-ideal "capacitor" there will be a second pulse and not the voltage doubling effect.
« Reply #7 on: December 29, 2018, 15:33:28 pm »
In the example of the video the voltage is always connected, in Meyer system the Interruption of the power source (pulse off time) is what "triggers" the collapsing of the inductor(s).
