Author Topic: The effect of magnetic and optic field in water electrolysis  (Read 1380 times)
Hi friends,
Look what i have found here.
Its a ver very nice document about adding magnets and laser diodes to the electrolysis proces. They claim 9 times better results.
Its a pitty that they didnt measure the isotopes of hydrogen during their tests.
Go have a look....
cheers
Re: The effect of magnetic and optic field in water electrolysis
« Reply #1 on: May 21, 2018, 04:12:36 am »
Its a very interesting document great find Steve! i took a first quick look and than i will read more to get the details
Meyer used some lens i believe the function is to probably to polarize and spread the radiation
In this work they indeed increased the hydrogen production but if you note how much power its using it become sort of not so interesting... however the magnetic field is a positive  news although magnets are expensive
« Reply #2 on: December 24, 2018, 15:23:11 pm »
I do know that magnet feilds will stop  or slow down scaling in water pipes  not sure what hapends   as it has been 15 year since I last look into it, but I do now have a new reason to look into it again  we will see
« Reply #3 on: April 20, 2019, 17:30:19 pm »
Any news on this subject?! I've been 6 years ago on this forum with a last post. This week I took a quick look what is going on. I was stunned by this find and even more surprised nobody tried this out. I'm back on H2 dry cells again by seeing this Dutch guy who is compressing H2 in a propane tank up to 15bar=about 150 liters! In combination with green laser and magnets this all gave me hope and an inspiration boost. Have to rebuild my cells and I ordered two green laser pointers on Alie. In the meantime I became a 3D printing specialist so enough skills and tools to build something. I will be back.
A nice easter to you all.
kind regards,
Leon.
« Reply #4 on: April 20, 2019, 17:33:45 pm »
that is a dangerous process and could cost you your life
« Reply #5 on: April 20, 2019, 17:38:17 pm »
If you want to save my life please explain why. If been working with pure hydrogen(H2) it's a friendly gass to work with.
« Reply #6 on: April 20, 2019, 17:43:28 pm »
here is the moment where I stopped because of a lack on storage possibility's for the hydrogen.
« Reply #7 on: April 21, 2019, 20:07:18 pm »
This is what I want to build as a test setup. A two plate setup. From down under trough the gap going up the green laser beam. It shines trough a lens which breaks the light as a straight line. I can add magnets on the surface of the lens. Gas can flow trough the upper holes where measurements can be done. There is a membrane between the two red inner rings. It is possible to 3D print lenses (see video) but maybe Plexiglas works too.
(https://knookl.home.xs4all.nl/waterstof/TEST%20SETUP.jpg)
