Author Topic: 2017 research interests/nano/microbubble  (Read 4630 times)
Re: 2017 research interests/nano/microbubble
« Reply #1 on: October 01, 2017, 20:54:07 pm »
thanks for the post   very interesting
« Last Edit: October 29, 2017, 06:49:04 am by Kevin Satterfield »
Re: 2017 research interests/Puharich
« Reply #3 on: November 29, 2017, 09:59:26 am »
Why does Puharich say his electronics diagram is "not shown properly during his lecture explanation?
  • Build it. Power it. Use it.
« Reply #5 on: February 01, 2018, 19:24:51 pm »
It may not include all elements.  At some point he had a hole in the ceiling, on out through the roof, because he was also using a low frequency standing wave.  (In addition to Keely's resonant frequency.)
« Reply #6 on: February 03, 2018, 07:59:20 am »
That's an interesting perspective alltho different from my own.After tinkering with it a little bit the perspective Im seeing are drive signals aren't actually shown properly in his block diagram in terms of explaining it.
« Reply #7 on: February 03, 2018, 21:00:14 pm »
Here's a picture of one example of a hairpin capacitor:
(https://s20.postimg.org/pscvmw3x9/Hairpin_Capacitor.jpg)
If this works like my original circuit, the output from the resistor will pump electrons from the second cap.  The outside of the first cap will have a hv potential.  With no output connection on the second cap, a positive charge will quickly build up on both of its plates and the case.  (Don't touch any of this, unless everything is discharged.)  The nano bubble ignition spark is wired like a spark gap in series with the wire going back to the transformer from the first cap.  The output from the positive cap hits the spark gap from a third electrode next to the arc.  This produces a very bright, two inch, light blue Ball Lightning.  This BL, without a series inductor, produces harmful UV, so use eye protection.  And capacitor polarity - indicated by the spot on top - is important.
Don't hook that resistor up to a flamethrower, unless you want to sell a lot of them.
« Last Edit: February 10, 2018, 03:24:56 am by tektrical »
