Author Topic: New kind of high current and high voltage DC generator  (Read 5571 times)
« on: September 04, 2017, 15:04:39 pm »
I have created a new type of generator is based on the homopolar generator but it has more voltage output theoretically
The basic idea is to use two magnetro magnets glued with their same polarities to a iron disk such that they can be very close to each other
than the iron disk must have holes to wind up a coil on the  toroid
it need two slip rings and put the disk to spin
i will verify the voltages that can be obtain..
« Last Edit: September 04, 2017, 21:06:35 pm by sebosfato »
« Reply #1 on: September 04, 2017, 15:44:04 pm »
For the slip rings to have very low voltage loss i imagined a copper bearing filed with mercury so it will have small friction and high contact area
« Last Edit: September 04, 2017, 21:07:08 pm by sebosfato »
Re: New kind of high current and high voltage DC generator
« Reply #2 on: September 04, 2017, 21:03:18 pm »
Speaker magnets would be big to get a good effect...
but it dont really need to use toroidal design
another way of constructing it very easy is using a bicicle wheel  than non toroidal magnets iron magnetic spacer and coils can be arranged and glued on the wheel
this will make it very easy to make the coils and all and get a good speed
« Reply #3 on: September 04, 2017, 22:11:54 pm »
This is the best d sign I found to do with the things I had
I used some transformer laminations to glue the magnets together with their conter field behind ... this way the coils over each magnet must have opposite direction of winding tô be connected start to end serially
« Last Edit: September 05, 2017, 08:46:38 am by sebosfato »
« Reply #4 on: September 04, 2017, 22:54:09 pm »
I wonder if Meyer was doing this with his epg systems
« Reply #5 on: September 05, 2017, 05:31:14 am »
well i think that if my design work i have just found a way to create propulsion devices we never though of! well maybe someone who didnt told us... like john quincy st clair
the first test i will do is to place the magnet arrangement over a scale and see if defy gravity
« Reply #6 on: September 06, 2017, 15:45:17 pm »
The only missing point to make the UFO is to have a way to transform energy into mass so that the mass can be converted back to energy to travel the outer space
ii believe something like anti-mater could solve the problem.. so it can be used during acceleration and than regenerated during de-acceleration
If the theory is correct!
Well as i said before i used the principle behind the homopolar generator where the magnet can be spin with the copper disk and it still have the same emf meaning that the magnet simply amplify the property out of space time being this manifestation and the speed what makes the EMF available... i simply created a way to make it in simple stacks... as there is no new theory nothing is new and it should work.
the insane part is that it gives a linear propulsion or generation possibility now that the disk never would have
« Reply #7 on: September 07, 2017, 09:57:11 am »
Hi Fabio,
When is the first flight of your ufo? ;-)
I must say that magnets always had my interest too. Specially that transformercore with a magnet build in. Maybe 1 day i will setup such test. See if power pulse in equals power out or even more?
Mono pole technic or magnetfield bending might bring also some options for magnet motors....
Have fun and enjoy it, mainly. Its a nice voyage :-)
