Author Topic: Something i never tried  (Read 2924 times)
« on: September 02, 2017, 20:07:10 pm »
Hello humans
I have found something that intrigued me!
We know that resonance is capable of making the current and voltage to be 90 degrees de-phased  allowing it to accumulate a lot of reactive power.
Guess what i just found!
i was researching for power factor correction and found that unloaded induction motors will have pretty much the same current that a loaded motor consumes, the only difference is that when the motor is loaded the phases are closer and when it is unloaded the phases get close to 90
the power factor being close to zero means no real power is dissipated
well what i see here is that maybe we don't need resonance to get pulses we want to break the water
the great advantage i see is that is possible to develop a motor to have a certain adjustable frequency input meaning that it will have the 90 degrees over the frequency range designed while it can maintain the relationship of rpm
My best guess is that we must try to find a way to use reactive power and a ac motor seem a good starting point to get there
Re: Something i never tried
« Reply #1 on: September 02, 2017, 21:51:04 pm »
Now what about having a dc current there too?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i think we have not investigated this side of the story
now i´m kind of thinking that the alternator in stan setup was doing a whole different thing than we imagined..
maybe and i say without any sure of this but i believe in stan claims but i dont believe what was exposed to the public was the real deal
would yourself expose that much without warranty?
i believe what kep stan alive was this simple fact that he never got the real deal shown to anyone
than when he was offered billions to stop the oil corporations got afraid because he was not negotiable man and so probably to find out more they tried to apear as investors to see if he was really onto something and what he was hiding!
is not hard task to do and according to the level of instruction he had i believe he hide it completely
If you had something that you can´t get a patent on it and use it inside another patent of a hydrogen generator for example you hide the real technology pretty well
for me he simply found a way to use reactive power as a power source for sure. probably something tesla patented already or someone else
well i imagine the alternator being used as a choke so basically driving it with a motor and using it connected as it was to work like a motor in series with the cell
i dont know if you understand what i mean
so watch this at 3:53 he says the rotor will never catch up the speed of the rotating magnetic field this is what create the reactive power that is not consumed but maybe we can put it to work
 https://www.youtube.com/watch?v=LtJoJBUSe28
« Reply #2 on: September 02, 2017, 22:31:14 pm »
« Reply #3 on: September 04, 2017, 02:32:05 am »
Has anyone understood what I mean?
« Reply #4 on: September 04, 2017, 13:46:47 pm »
this is why i say alternator can be used as a sych motor
https://www.youtube.com/watch?v=Vk2jDXxZIhs
« Reply #5 on: September 04, 2017, 14:10:12 pm »
« Reply #6 on: September 06, 2017, 14:24:15 pm »
Hello for those who have the alternator setup I propose the following tests
First take a cheap wattmeter put at the input of the motor driving the alternator
Now get the 3 phases center conection and apply a 12v there from elsewhere and also energize the field coil
Put the alternator to run and measure the input watts change when a D.C. Current is running from there
The negative of the D.C. Voltage should also be connected to the negative of the load
The load can be a water cell use a wattmeter also there
This D.C. Current will create some difference in the way of the alternator works not sure what will be the results that's why it need to be tested
Next test is:
« Reply #7 on: September 08, 2017, 12:41:13 pm »
That done now is time to get the chokes after each diode... what it will do?
It will dephase the peak current and forced distribute the current over  the coils... the result ?
Well the load will look lighter and...
Maybe the chokes could be in a common core this would make the frequency multiply
« Last Edit: September 08, 2017, 13:32:40 pm by sebosfato »
