Author Topic: New interpretation new topic  (Read 2928 times)
« on: May 18, 2017, 08:37:04 am »
Hello my dear friends
I found today some new way of  interpreting the electron extraction grid it may be of some help to lead us to discover how to make Stan secretes come up...
I was thinking about the water cell as being the source of electrons and think about who could be the sync for them to allow power to be generated than an old idea came across
We have a certain important characteristics we must not forget
Gas is generated
The car engine works as a gas pump
A gas can be ionized
Hv D.C. Is involved
Low voltage high current is involved
Power is generated
Meyer says that the gas could be neutralized passing thru grounded tube
So my thoughts are
The low voltage generates the gas
The gas bubble out
The high voltage makes the bubbles loose electrons that will sit on water
The ionized gas will be repelled from the water bath and run thru plastic tube
At this point the gas will be at a higher potential than it were when it was a bubble
So now the gas enter the eec working as an electron sink to extract electrons that remained on water generating power thru a external circuit !
« Last Edit: July 04, 2017, 22:03:33 pm by sebosfato »
Re: New interpretation new topic
« Reply #1 on: May 18, 2017, 10:09:21 am »
is HV not dangerous with HHO?
« Reply #2 on: May 20, 2017, 08:51:36 am »
Probably yes but we need to figure how to make it safer.... maybe with lot of air being bubled together with the buo it become safer
« Reply #3 on: May 26, 2017, 23:10:35 pm »
To be more clear the whole idea is to use the water cell passing thru it a certain amps to generate gas but hold the water at high voltage potential this will allow ions to be formed as the bubbles get out of the water, the bubbler can have a specific geometry to enhance the electric field at the bubble formation....
The ions are driven by the engine air pumping upwards getting sway from the high voltage potential zone as they have same polarity
Here the system present a discontinuity where the ions go away in a hydraulic system but they can give their charge out as soon as it pass thru a metallic tube! During this stage another gas can be formed depending on the conditions present. Because the ions can react with other gases present specially in the presence of a catalyst.
The electron extraction works like charging and discharging a capacitor is required to discharge to charge again!
« Reply #4 on: May 29, 2017, 15:55:21 pm »
the high voltage ckt is going to have the ionization current ...I'm thinking that the ecc is going to reduce this because the electrons will have other way to go ! Basically the idea is that the ions will get pumped in energy by collisions with a metal target energizing the allowing to be further stripped off electrons ... like a chain every step will have its own ckt
« Reply #5 on: June 05, 2017, 01:24:30 am »
Multipacting for exciting atoms to reach higher ionization leves
« Reply #6 on: June 05, 2017, 18:40:38 pm »
When multipacting is achieved the voltage will peak at the input coils as the multipacting creates a short ckt like effect drawing power for the resonance
  • Build it. Power it. Use it.
« Reply #7 on: June 06, 2017, 18:43:15 pm »
I think we're starting to understand how it works.  Electrons are removed on impact with the outer tube, due to its positive potential. When we add in ionization electrons which are produced by collisions between the molecules themselves, these electrons are removed by the charge pump extraction ring.
