Author Topic: Anderson Rebuild  (Read 2330 times)
Anderson Rebuild
« on: February 09, 2017, 20:14:54 pm »
It has begun  8)
Re: Anderson Rebuild
« Reply #1 on: February 12, 2017, 09:49:30 am »
Finally got both electrodes off and some measurments documented.I deffinatly over killed on silicone....after ten years the stuff is still very hard to get off.
Case width. is just shy of 3 and 3/8 inches.
Case O.D. is 14 and 1/4 inches
Case I.D. is 12 and 3/4 inches
Part # is located somewhere on the internet that I posted in 2006.Its a female adapter part to some type of construction line.I found mine in a ditch on a job site in Atlanta luckily with the label on it but where is my picture now ?
You can get a 12" schedule 80 gray pipe from eBay now under 100 usd that would work.
« Last Edit: February 15, 2017, 20:40:17 pm by Newguy »
« Reply #2 on: February 13, 2017, 07:42:58 am »
Sensor A location and housing
PVC threaded pipe plugs work perfectly for sensor insert.Magnetic(transverse) field strength tracking is essential for operations.
« Last Edit: February 13, 2017, 21:10:53 pm by Newguy »
« Reply #3 on: February 13, 2017, 23:37:56 pm »
good stuff!
« Reply #4 on: February 14, 2017, 10:50:42 am »
good stuff!
For me this is as far as it goes until this step is completed.
To me this is a DC component whether it gets chopped up later or whatever that must be completed or at the very least fulfilled.... There are some more components of this step to me and everything forward will be applied to this step.I have to have the ability to create at 1826 gauss magnetic field and of course....I HAVE to have a way to measure it.
There is one common factor in EVERYTHING including the electron and proton and that to me is .....distance.....meaning there is a reason things are at a distance and a reason why things are not there at a distance.
The quest is to have control of distance (Space) .
« Last Edit: March 16, 2017, 19:49:58 pm by Newguy »
« Reply #5 on: March 16, 2017, 19:56:58 pm »
FYI
This is the part I'm rebuilding.This particular piece could only handle less than 2 amps.My new piece can handle more than 20 amps.It is the only way I have found to produce an appreciable magnetic field between the electrodes.
Its not so obvious I guess that those electrodes are off my mini cell(5").  ....the piece is made for the full version is why it looks so large.
« Last Edit: March 17, 2017, 10:46:06 am by Newguy »
