Author Topic: Old cows new insides?  (Read 5656 times)
« on: September 15, 2016, 17:40:12 pm »
How Meyers setup works according to Ted Zettergen:
If you read something about magical frequencyis, forget that. It works fine with 10KHz or something else if you preferred. Use 50% duty cycle. BUT! the frequency will be doubled in the step up circuit and that's the frequency the Water-Cell will work with. The components must resist at least 2000V.
The Water-Cell is very simple. Take a lot of stainless steel tubes with the inner diameter of the bigger tube 3mm bigger than the outer diameter of the inner tube. From now you must look at this Water-Cell as a capacitor with water as dilectricum.
The Water-Cell and the INDUCTOR will resonate at a specific frequency. It's a normal RC-circuit.
Now the most important: The Water-Cell/Inductor frequency and the doubled frequency from the generator must be exactly the same. A special condition exists in a L/C Circuit, when it is energized at a frequency at which the inductive reactance is equal to the capacitive reactance, XL = XC.
Adjust the voltage peak level to reach a maximum hydrogen/oxygen producing with a minimum of current using. If you earlier make hydrogen with the electrolysis method with a lot of current, this experiment will really surprise you.
For even less current you can make some experiment with a centertapped puls-transformer.
« Last Edit: September 15, 2016, 18:01:26 pm by Steve »
Re: Old cows new insides?
« Reply #1 on: September 15, 2016, 18:00:09 pm »
The key to the Meyer process is resonance, and without resonance the
system produces no gas. At 12watts you see why no gas is produced
without resonance. This is a standard LC resonant circuit in which you
MUST (!) match Capacitive reactance with Inductive reactance. This
then creates an LC resonant circuit in which the two legs of the power
supply match in frequency exactly
. A Ham calc make the calculation of
resonance easy once you know the capacitance of the cell and the
frequency you are driving it at. Once you have your inductance
calculated you then buy the proper chokes 07/24/2005 12:18 AMYahoo!
Groups : energy2000 Messages : Message 20771 of 25951 Page 4 of
6http://groups.yahoo.com/group/energy2000/message/20771 that fall
within the inductance range needed. The adjustable one needs
(obviously) to be tunable within a small range, so that when the cell
temperature changes and causes the capacitance of the cell to change,
then the inductance can also be changed to keep the cell in resonance.
If you cell has the ability to vary distance between conductors, then
you simply change the distance and thus change the capacitance of the
cell rather than changing the inductance. You must vary one of the
other though. I have found since then that the capacitance of the cell
can be changed and works just as well as the inductors being adjusted.
You don't use ANY electrolyte, you don't want ANY amperage at all,
only voltage @ resonance. REPEAT, YOU DON'T NEED ANY CURRENT FLOW,
ONLY VOLTAGE!
« Reply #2 on: September 15, 2016, 23:02:34 pm »
Hi Steve.
Nice to see you are there, this forum almost stopped.
There are other people claiming the same like UncleFester (Tad Johnson) but no one showed it.
It looks to  be unreachable to us, water varies the dielectric constant in function of frequency and temperature.
« Reply #3 on: September 16, 2016, 09:24:13 am »
Well, its my forum, so i am always here  :) ;)
Do you have any idea on how to calculate or to measure the capacitance of a waterfuelcell?
cheers!
« Reply #4 on: September 16, 2016, 11:21:48 am »
Did anybody tried this methode:
https://en.wikipedia.org/wiki/Schering_Bridge
« Reply #5 on: September 16, 2016, 13:55:07 pm »
cheers!
Dry the cell completely and measure it with air.
Air dielectric is very near to 1.
Then multiply by the water dielectric constant.
I made some experiments with paper as dielectric and it correspond correct.
By the way I have some doubts abou wfc behaving like a real capacitor...
« Reply #6 on: September 17, 2016, 11:38:48 am »
cheers!
Ok Xblade. The cell is now drying in the sun....
Lets see what the single cells will show and what they do in series....
thanks!
« Reply #7 on: September 17, 2016, 13:51:49 pm »
I have some thoughts to share and discuss with you, since nobody cares on the Russ forum because I am on Max Miller forum.
