Ready for tests
i got a bycicle to instal the engine and it end up really nice it runs pretty well on gasoline...
i will try to get some pure gasoline by adding water to the gasoline and therefore dissolve and split the alcoohol contained in our gasoline... here is 27% its a law here as here the country produce a lot of it...
now i need to determine if it has a waste spark that will be there probably and find a way to get rid of it... any ideas?
i will finish a big cell with many plates to get the gas for it initially and determine the flow rate required... this cell is a 9 cell in series to give 1.5 v per cell .. . will be feed from wall initially...
i will be working on the increasing of power output of the same gas being generated by trying to stimulate some atoms to fuse together under combustion conditions...
this is my goal with all this... to prove that meyer was the same as horvath theory in that they were extracting some fusion energy by stimulating the gases with photons and voltage..
http://www.bicycle-engines.com/49cc-engine-parts-diagram.html
