Author Topic: VIC 24 AWG - COPPER?? I dont think so!  (Read 2598 times)
« on: May 30, 2016, 20:15:50 pm »
Today i bought 1KG of enamelled wire 24 AWG (0,5mm), my big surprise when i measure the total resistance of the bobin:
50 OHMS!
Less resistance than secondary coil  on the VIC from the dune buggy.
This let me think a little bit...
I dont want to doubt about Don's honesty but...
Was it really copper??
Was the measurements right?
Was all of us fooled with this wrong information?
Is this why nobody can put it to work?
I measured with 2 different multimeters, and both gave me the same values...
What a f..... was that?
1kg is about 553 meters (50 ohms!)
Re: VIC 24 AWG - COPPER?? I dont think so!
« Reply #1 on: May 30, 2016, 21:58:42 pm »
You waisted your money.Stan used 29awg double coated magnet wire.Everything about the wire, coils makes sense,nothing is trown there randomly,and Dons
's measurements are right.
« Reply #2 on: May 31, 2016, 00:07:37 am »
Maybe you are right.
But what kind of magnet wire?
« Reply #3 on: May 31, 2016, 02:08:21 am »
29awg copper double coated wire is what seems have appeared on the vics
but stan talks about using 24 awg for chokes and 36 for secondary elsewhere
« Reply #4 on: May 31, 2016, 13:50:36 pm »
sebosfato can you link where did you found that?
A cant find the post from Dynodon where he talks about it was copper wire.
« Last Edit: May 31, 2016, 19:08:49 pm by X-Blade »
« Reply #5 on: June 01, 2016, 13:03:58 pm »
well i tried and the coils have same resistance per lenght of wire as stan....
using 29 awg... its a lot of meters into each bobin all have around 280meters
« Reply #6 on: June 01, 2016, 13:51:04 pm »
I saw a picture in his forum taken by Don measuring 0.0155" to 0.40mm aprox
AWG is different from SWG some people think it is the same.
