Author Topic: harmonics discussion  (Read 6117 times)
« on: February 02, 2016, 16:26:16 pm »
Hi,
Might it not be that the step charge waveform is nothing more then the steps you see on a waveform including harmonics?
Harmonic induced by chopping circuits,
3rd harmonic means you observe 3 peaks near amplitude of half sine wave,
5th harmonic means you observe 5 peaks in half wave .
harmonic disturb to capacitive current and inductive current ,
due to harmonic capacitive current increase and inductive current decrease
see 1:20
https://www.youtube.com/watch?v=hJo-PkaXJ_k
Re: harmonics discussion
« Reply #1 on: February 02, 2016, 16:37:02 pm »
Look at the wave forms.
Are they not similar as Puharich wave forms?
https://www.youtube.com/watch?v=pUzx1J7CEZo
« Reply #2 on: February 02, 2016, 16:39:01 pm »
The additional harmonics, Puharich says, cause the proton in the hydrogen atom TO ROTATE, further forcing the hydrogen to split from the oxygen.
The sine wave carrier converts to a rippled square wave pulse which reflects the RC time constant of water, and it is observed that the square wave contains higher order harmonics.
The wave form now automatically shifts to a form found to be the prime characteristic necessary for optimum efficiency in the electrolysis of water and illustrated in FIG. 11. In the wave form of FIG. 11, the fundamental carrier frequency, fc = 3980 Hz., and a harmonic modulation of the carrier is as follows:
1st Order Harmonic Modulation (OHM) = 7960 Hz.
2nd Order Harmonic Modulation (II OHM) = 15,920 Hz.
3rd Order Harmonic Modulation (III OHM) = 31,840 Hz.
4th Order Harmonic Modulation (IV OHM) = 63,690 Hz.
What is believed to be happening in this IV OHM effect is that each of the four apices of the tetrahedron water molecule is resonant to one of the four harmonics observed. It is believed that the combination of negative repulsive forces at the outer electrode with the resonant frequencies just described work together to shatter the water molecule into its component hydrogen and oxygen atoms (as gases). This deduction is based on the following observations of the process through a low power microscope. The hydrogen bubbles were seen to originate at the electrode rim, 4', of FIG. 3. The bubbles then moved in a very orderly `pearl chain` formation centripetally (like the spokes of a wheel) toward the center electrode, 1' of FIG. 3. FIG. 12 shows a top view of this effect.
All from Puharich
« Reply #3 on: February 02, 2016, 16:58:56 pm »
Hello Steve
You think than we should add all the frequencies isolated from each other?
or you mean like Fm frequency modulation... you canachieve that with a pll too... but you need the modulation signal to be like a triangle ramp or sine....
meyer resonant scanning circuit is interesting but it can find lock and all but it only looks for nice frequencies if we modulate it it can create many harmonics...
« Reply #4 on: February 02, 2016, 17:18:43 pm »
all harmonics are super imposed, if you add them all together...
Sebosfato, i am not sure, but Ron somewhere wrote that you should put an AM radio close by your VIC.
The more noice you hear over a larger bandwidth, the better yr VIC works.....
For me, that sounds like a lot of harmonics.
Transmitted into the water, like a very very dirty AM transmitter....
« Reply #5 on: February 02, 2016, 17:21:03 pm »
Puharich claimed to have discovered a connection between all parts of the watermolecule as they seems all harmonic related with eachother.
So, if you hit the right base frequency and yr transformer is doing the harmonics, you automatically hit all components of the molecule.
« Reply #6 on: February 02, 2016, 17:22:43 pm »
Thats also probably what Bob Boyce once seen as effect with his crazy toroid.....
Creating harmonics.....and then try to transmitte them into yr waterbucket
« Reply #7 on: February 02, 2016, 17:30:16 pm »
YOU SHOULD ASK THE RIGHT QUESTIONS!!!!!!!
I sometimes feel so stupid.
Look here what harmonics did to a CAPACITOR!!!!
Imaging a watercapacitor.......
