Author Topic: Could you run a gas furnace with the output from these cells?  (Read 2757 times)
JTJB
Would it be more efficient to create hydrogen and burn it as a flame to heat a typical gas furnace OR would using straight electricity by heating the coils in a typical forced air electric furnace be more efficient?
« Last Edit: May 08, 2008, 08:59:40 am by JTJB »
Re: Could you run a gas furnace with the output from these cells?
« Reply #1 on: May 09, 2008, 02:40:25 am »
1 kW of electric heat will make 3413 BTUH. So I guess the next question would be how many BTUH can you make using 1000 watts of power with a hydrogen generator?
