Author Topic: How the VIC Works - IMPORTANT!  (Read 45853 times)
0 Members and 27 Guests are viewing this topic.
Re: How the VIC Works - Induced DC Current Voltage
« Reply #88 on: April 21, 2015, 03:21:34 am »
This is the wave form we are looking for is it not?
I'm presently working with 1kV to 2kV peaks with very little current.
I am presently running with a resonant frequency around 6.8kHz and a very low gate pulse, probably around 30Hz.  Duty cycle on the primary frequency is high.  Duty cycle on the gate frequency is low.   You can see the frequency doubling in the pic as it shows 18kHz.  The voltage doubling is also present.
Obviously, these frequencies are setup specific.
I'm not happy with the step up as it drops two steps before each step up.  Seems to be related to the output of one of the PWMs.
« Last Edit: April 21, 2015, 19:16:54 pm by timeshell »
« Reply #89 on: April 21, 2015, 14:32:25 pm »
How did you measure TS? Over the cell, or coils included?
And did you see already more gas?
« Reply #90 on: April 21, 2015, 14:41:48 pm »
Over cell and coil coupled to primary.   No gas yet.  Still perfecting the wave form and voltage intensity.
« Reply #91 on: April 25, 2015, 01:11:21 am »
In short, I have come to a reasonable certainty that Tony's VIC circuit as is is not capable of working correctly to charge the water cell.
Also from my experiences with my PWMs and my observation and studying the 4046 chip, I believe that using the 4046 as the main frequency driver is not suitable and will never produce the desired result.
Alternatively, there is a problem with my copy of the circuit that I haven't yet been able to determine.
However, I will also not pretend that I have high experience  or am an expert using 4046 or circuit design.  I could be wrong.  I am just commenting about my experience and conclusions up to this point.
I have turned instead to the boards being provided by Ronnie Walker and Neal Ward at http://www.stanmeyerreplications.net and will start testing with them this weekend.
« Last Edit: April 27, 2015, 05:21:42 am by timeshell »
« Reply #92 on: April 25, 2015, 14:09:40 pm »
good luck this weekend TS
cheers
« Reply #93 on: April 27, 2015, 05:21:04 am »
Haven't gotten to actual testing yet.  Assembled most components and waiting for some more to come on Tuesday.
« Reply #94 on: April 29, 2015, 18:47:22 pm »
First pic of sperm wave of resonance signal using RWalker and Neal Ward circuits.
« Reply #95 on: April 30, 2015, 22:08:18 pm »
WFC improvements.  Sealed outer tubes in industrial electrical shrink tubing.
