Author Topic: How the VIC Works - IMPORTANT!  (Read 45849 times)
0 Members and 27 Guests are viewing this topic.
Re: How the VIC Works - Induced DC Current Voltage
« Reply #16 on: March 02, 2015, 17:11:37 pm »
Maybe.  However, I'm not convinced wire resistance is the primary focus yet.
« Reply #17 on: March 02, 2015, 17:16:54 pm »
wel the resistance play an important role if impedances are not matched there are reflections and so power absorbed by the load can be almost 0 witch actually is what we should want but we need to get the charge to the water molecules for them to break apart The water molecules get charged when the high electric field is applied and retain its charge for a time called relaxation time...  it seems a fight between order and heat...
My question to you is what is and where is the load?
« Reply #18 on: March 02, 2015, 17:20:42 pm »
Resistance is at its maximum due to resonance and opposing currents.   I'm not sure that the wire resistance itself has any important effect.
« Reply #19 on: March 02, 2015, 17:25:31 pm »
If the cell is a short circuit the amps goes to zero as stan stated.....
If the cell is a high impedance actually the line will have a short circuit facing it... so the current goes to a maximum
High voltage should be present however in both cases so fas as i know
it depends on the load... this kind of transformer has only to do with frequency and length but this is not the only things to be matched... i'm taking a deep look into it...
« Reply #20 on: March 02, 2015, 17:33:00 pm »
there may be a condition where the cell goes to high voltage regime and the water retain the charge...
« Reply #21 on: March 02, 2015, 17:35:35 pm »
I think you should re-read Andrija Puharich's patent.
http://www.globalkast.com/docs/Andrija%20Puharich%20-%20US4394230.pdf
« Reply #22 on: March 02, 2015, 17:42:57 pm »
Right now I am getting 400V DC spikes going across each choke with nearly 0A.
« Last Edit: March 02, 2015, 18:14:01 pm by timeshell »
« Reply #23 on: March 02, 2015, 18:18:07 pm »
The problem is to get this voltage in the cell bro... across the coils there should be 20kv or so for that
