Author Topic: Learning  (Read 3187 times)
Learning
« on: July 30, 2014, 04:13:12 am »
Today i learned more about power and switching transformers, how to design and understand its losses and capabilities...
http://ludens.cl/Electron/trafos/trafos.html
http://ludens.cl/Electron/Magnet.html
Re: Learning
« Reply #1 on: July 30, 2014, 04:32:09 am »
I found that the aluminum case covering up the vic improves coupling and is a technic for doing that which consists of adding a shorted conductive foil around the core.. this contains the field inside...
https://www.youtube.com/watch?v=3b8Wol-X4tE
look the common mode
https://www.youtube.com/watch?v=6681mgFNomc
« Last Edit: July 30, 2014, 05:01:20 am by sebosfato »
Re: Learning
« Reply #2 on: July 30, 2014, 05:55:23 am »
https://www.youtube.com/watch?v=-GgB03vlNzU
how to make your own transformer...
this video teaches strange formulas that seems to work well ... including the power handling of the transformer and section of the wires...
the area of the core according to this video should be equivalent to the square root maximum power at the primary at full load, that is the maximum power developed in the secondary divided the efficiency percentage in decimal numbers..
It ends up with what seems a well sized transformer...
here some lamination power http://www.construyasuvideorockola.com/transformador.php
« Last Edit: July 30, 2014, 12:36:17 pm by sebosfato »
Re: Learning
« Reply #3 on: July 30, 2014, 09:19:45 am »
Thank you, Fabio.
Great stuff :-)
Re: Learning
« Reply #4 on: July 30, 2014, 12:41:51 pm »
Your Welcome Bro!
check this... the case information i took out of one of this books in attachment
Re: Learning
« Reply #6 on: July 31, 2014, 10:45:40 am »
The term "Flyback Transformer" is a little misleading and its more useful to consider it as coupled inductors rather than a transformer because the action is quite different with a conventional transformer energy is going into the primary and out of the secondary at the same time it does not store energy. With a "Flyback" transformer energy is first stored then released.
Re: Learning
« Reply #7 on: July 31, 2014, 10:47:11 am »
The energy storage is therefore only possible in the air gap and is proportional to be air gap volume and the square of the flux density.
