Author Topic: Rotating magnetic fields  (Read 1377 times)
« on: July 14, 2014, 09:34:52 am »
I was guessing what if we could create a magnetic field but instead of turning it mechanically around if it were possible to make it to permanently rotate as long as the field exist...
Re: Rotating magnetic fields
« Reply #1 on: July 15, 2014, 21:17:07 pm »
field synthesis again why not mechanically rotate it? just rotate a coil and you have a rotating magnetic field.
« Reply #2 on: July 16, 2014, 02:10:46 am »
I was wondering if it weren't possible that if you get a electrically rotating magnetic field in a way that we could create power with that...
i have this impression that if the coil is already charged the energy could be translated to another coil located at a space relationship from the first coil and so on such to make the field walks like... if that happens than where will the back force applied to?
« Reply #3 on: July 16, 2014, 05:55:01 am »
lenz law will apply normally I guess
