Author Topic: Free Energy Must See  (Read 3677 times)
« on: July 06, 2014, 23:03:21 pm »
Re: Free Energy Must See
« Reply #1 on: July 07, 2014, 01:24:25 am »
Big building AC units use chillers which are Cooling units that cool water and pipe it into the building to what is normally called a evaporator. So its still using a freon based system but only to cool water and pump it into the buildings cooling system.. When I used to weld commercially I replaced a unit one time.
« Reply #2 on: July 07, 2014, 02:18:08 am »
Did you watch the video, there is a turbine being spun by the refrigerant as it boils into a vapor. They're saying two of these can generate enough electricity to run a small city.
« Reply #3 on: July 07, 2014, 05:01:53 am »
Geothermal
they simply got a way to tap geothermal power... not really free energy...
« Reply #4 on: July 07, 2014, 06:59:04 am »
I think this is about as close as one could ever get. All you need to power your entire home is a single well.
« Reply #5 on: July 07, 2014, 07:47:21 am »
I was just referencing to the point where you spoke about the hospital AC unit how it is a chiller..
Yes i like the idea presented with this.. very interesting stand point using mediums which boil at much lower temps than water.
« Reply #6 on: July 07, 2014, 16:17:51 pm »
I would like to do this on a residential unit just on a smaller scale. But I cant think of what to put in the refrigerant line to act as a generator. I could do this is since I have all the tools.
« Reply #7 on: July 07, 2014, 18:15:32 pm »
I think you could use air-conditioning refrigerant, like 410r  that is non aggressive to ozone...
In order to make that you are also going to need a vacuum pump
pressure gauges, tubes, flanges and copper tubing
and probably an air conditioning pump to get the gas in....
the idea is indeed very smart... because you can extract more power from the lower temperature side this way...
It could be used to generate energy from solar water panels too! as long as you have cool water to use.
You just need a heat sync and a cold sync
