Author Topic: How to find the efficiency of a fuel cell  (Read 27677 times)
Re: How to find the efficiency of a fuel cell
« Reply #24 on: April 29, 2008, 04:21:54 am »
that still isnt that great compared to stans alternator he made all his gas with 24 watts  measured at the cell
to be exact was
                            4.4 amps  and 5.6 volts  with 9 tubes
                            2.6 amps  and 7.7 volts  with 2 tubes
                            2.0 amps  and 7.6 volts   with 1 tube
  the rotor imput was  1.5 volts and .25 amps   huge difference from what you guys are doing his method was surgical not brute at all  these number are a deffinate fact
no topsy, stan used 10 watts to the primary side of the transformer to run his car, he also used a 2 thousand watt motor to do it. Also the only information about stans Water fuel cell is found on page 60 of the document floating around, he says he used 12.5 volts and 40 amps 500 watts to the fuel cell wich produced 7 liters of gas. I wish i could say more.
if you guys are producing what you say you're producing without additives, then more power to ya. if this is so, then i can assure you if stan was alive this would get his attention! your production is wacked, i just have to see it to believe it.
Poc should be posing his setup etc,, he to has a setup that is mind throwing like yours, if what you guys have works like you say then this technology just got a major makeover.
if you happen to run across this information again topsy, let me know cause we wanna see what you're referring to.
« Last Edit: April 29, 2008, 04:29:46 am by hydrocars »
  • Pochin Hydrogen
  • Hydrogen to Drive
    • PochinTwin Hydrogen
« Reply #25 on: April 29, 2008, 04:37:40 am »
50v
7.5a
375 watts
0.15L
8.5 sec
1.07lpm
tap water only NO additives
plate config +nnnnnnnnnn-nnnnnnnn+nnnnnnnn-nnnnnnnn+nnnnnnnn- etc
69 plates
« Last Edit: April 29, 2008, 05:05:03 am by pochintwin »
« Reply #26 on: April 29, 2008, 04:50:40 am »
there you go obiwan dig in!
« Reply #28 on: April 29, 2008, 10:32:00 am »
This is a comperison of results I collected from this thread. Please correct me if there are any mistakes.
Hm
« Reply #29 on: April 29, 2008, 11:27:54 am »
Thats over my head!
jbhuffinstuff
« Reply #30 on: April 29, 2008, 14:34:31 pm »
i guess im wrong according to that page      :)
« Last Edit: April 29, 2008, 16:18:11 pm by topsykretts »
« Reply #31 on: April 29, 2008, 20:36:53 pm »
Have you guys seen what John Aarons is doing on hydrogen tap. The only problem is he is using an additive.
