Meyer refer to resonant action explaining that is all about movement and deflection of the ions... I worked this days with many concepts of magnetism and some new exiting experiments that are keeping me from sleep and simply i decided to think about the resonant action stan proposed again.. I was thinking about what if we could simply create a high voltage strong field but instead of pulsing it and its than switched off and reverse the polarity in a ballistic manner to collide the ions and electrons in the bath. The idea is: choke connected in series to a dc source a secondary of a transformer and the cell, the primary is wound facing the secondary and this is pulsed in such a manner that the pulse sums to the dc during pulses on an rapid enough completely reverse the polarity of the cell shooting the ions back into the water as the magnetic field collapses ... as the ions cannot go fast enough they get ionized and the electrons should create an avalanche like effect. So basically you are applying Dc and a Pulsed current at the same time...
Th steam resonator should be te same but he probably switch the polarity before the gas is released from the reaction...
Heres how i see it(http://www.ionizationx.com/index.php?action=dlattach;topic=2855.0;attach=13365;image)
Quote from: Login to see usernames on March 08, 2014, 01:55:05 amHeres how i see it(http://www.ionizationx.com/index.php?action=dlattach;topic=2855.0;attach=13365;image)Yes, like whiplash...jp
Quote from: Login to see usernames on March 08, 2014, 06:44:03 amQuote from: Login to see usernames on March 08, 2014, 01:55:05 amHeres how i see it(http://www.ionizationx.com/index.php?action=dlattach;topic=2855.0;attach=13365;image)Yes, like whiplash...jpNotice that Vo situation to Vn situation vary with duty cycle applied to the transformer. the wave form is not going to be like that but the Vn is the level between the positive pulse and the negative pulse. (the zero level)
