Author Topic: EPG simple and Stupid Theory  (Read 2565 times)
« on: February 28, 2014, 11:05:22 am »
I have developed a new theory for the operation of the epg. The electrical particle generator
Tell me what you think please.
The idea is:
The tubes forms a flat coil... this coil is put to resonate with a capacitor or is preferably pulsed to yeld high voltage at the collapse... This forms an Rf field that ionizes and create an oscillation in the ions inside it. like a strong bang
This oscillation together with applied magnetic field by the coils that surrounds the flat coil forming a toroid it creates RF field in the other direction so it can be extracted by output coils...
Since the initial oscillating field is 90 degrees geometric configuration the coupling is zero or almost zero if you want...
the atoms can enter into precession movement that converts the magnetic field into energy... i guess
The inside of the tube must have heavy insulation to get rid of the ions discharging to the tube and reducing the Q factor of the flat tube coil... maybe it could be coat with teflon to help lowering hydrostatic resistance
Re: EPG simple and Stupid Theory
« Reply #1 on: February 28, 2014, 11:20:29 am »
Notice that in all his drawings it forms a solenoid or a flat coil...
« Reply #2 on: February 28, 2014, 23:36:56 pm »
I believe that he used the hooper force.. I'm short on time these days .. I want to try and see if I can work out some formulas...
« Last Edit: March 01, 2014, 00:20:21 am by geon »
« Reply #3 on: March 01, 2014, 07:48:40 am »
trouton-noble experiment......http://jnaudin.free.fr/html/troutnbl.htm
« Reply #4 on: March 04, 2014, 19:55:14 pm »
A non-uniform electrical field will generate a net attractive force on a neutral piece of matter. The force is directed toward the region of higher field strength.
« Last Edit: March 04, 2014, 20:25:55 pm by geon »
« Reply #5 on: March 06, 2014, 21:45:15 pm »
the motional electromotive force creates a divergent electric field, molecules are a neutral piece of matter.
« Reply #6 on: March 07, 2014, 02:54:56 am »
I really would like to understand the terms you use...
« Reply #7 on: March 07, 2014, 06:31:41 am »
the molecules and ions are tiny dielectrics .. when they move in the same speed their motional emf creates a divergent electric field and the electrons in the orbitals moving around have a speed dont they if you accept that they don't just teletransport to their places
« Last Edit: March 07, 2014, 06:51:17 am by geon »
