Author Topic: Stan Meyer Water Fuel Cell Parameter  (Read 2246 times)
« on: December 16, 2013, 14:41:27 pm »
From transcript of 1989 Lab Visit:  October 16 1989  7:47 AM
Stanley Meyer:  "As I said, if you hit this fuel cell at 5000 volts at 50 kilohertz, you can convert a gallon of water a second"
He is referring to the demonstration unit in his Grove City laboratory. Does this statement seem credble?
(The tubular cluster array cell held slightly over 2 gallons of water when filled)
« Last Edit: June 27, 2015, 14:44:16 pm by jim miller »
Re: Stan Meyer Water Fuel Cell Parameter
« Reply #1 on: December 16, 2013, 15:27:18 pm »
I think it sayd 50hz because neither the alternator or the 8xa canot produce 50khz,i think he just asumes because the test results showes 12v,40A
« Reply #2 on: December 16, 2013, 15:38:22 pm »
Stan said 50 kilohertz so maybe he was talking about an experiment we haven't seen?
« Reply #3 on: December 16, 2013, 18:19:04 pm »
Gallon of water converted in a second sounds unrealistic.. unless its a industrial sized unit that has more than a gallon of water cell gap space..
« Reply #4 on: December 16, 2013, 18:40:31 pm »
Agree with outlaw,it sound irealistic,one galon is 4L of water,how an earth a jag of  4L disapeares in 1sec?He definetly exagerated.In the newsreleases he talks about 2galons per HOUR conversion rate,was needed to drive the dunebugy at 50mph...He just asumes he said ''IF''and thats a big if...
« Reply #5 on: December 18, 2013, 03:57:10 am »
He meant with the "size capacitor' on the bench....amount of tubes.....configured properly..that amount of steel 'hit a 50khz/5000 volts will '"polarize" "a gollon of water a second'...it would act like a steam pump...as he shows in one patent...air/gas pump getting power from liberated gas pressure from cell..."law of economics' feed back loop....his way of making 'efficiencies"..over and over....
look at earliest Canadian Patents...fuel cell gas generator...
good luck,
jp
