Author Topic: Gift of the day: Sequential Pulse generator  (Read 1079 times)
« on: November 26, 2013, 14:35:52 pm »
(http://www.ionizationx.com/index.php?action=dlattach;topic=2791.0;attach=13055;image)
$ 1 1.24E-6 7.308818067910767 38 5.0 43
v 288 368 288 144 0 0 40.0 20.0 0.0 0.0 0.5
l 464 224 464 304 0 0.01 0.008040215805947572
l 560 224 560 320 0 0.01 0.0820364503838856
d 464 96 464 224 1 0.805904783
d 560 96 560 224 1 0.805904783
d 656 96 656 224 1 0.805904783
d 752 96 752 224 1 0.805904783
l 656 224 656 320 0 0.01 1.3379820925134185
l 752 224 752 320 0 0.01 14.697862252809996
w 288 96 464 96 0
w 464 96 560 96 0
w 560 96 656 96 0
w 656 96 752 96 0
d 464 368 560 224 1 0.805904783
d 560 368 656 224 1 0.805904783
d 656 368 752 224 1 0.805904783
d 752 368 832 224 1 0.805904783
w 464 224 512 192 0
w 512 192 832 192 0
w 832 192 832 224 0
g 288 368 288 400 0
w 464 368 464 400 0
w 560 368 560 400 0
w 656 368 656 400 0
w 752 368 752 400 0
g 464 432 464 480 0
g 560 432 560 480 0
g 656 432 656 480 0
g 752 432 752 480 0
163 368 576 480 576 0 10 0.0 0.0 0.0 5.0 0.0 0.0 0.0 0.0 0.0 0.0
R 368 608 304 608 0 2 1000.0 10.0 0.0 0.0 0.5
w 528 544 528 528 0
w 528 528 800 528 0
I 800 528 800 640 0 0.5
w 800 640 688 640 0
w 416 496 400 544 0
w 432 544 512 464 0
r 416 496 416 416 0 10.0
r 512 464 512 416 0 10.0
w 464 544 512 496 0
w 512 496 608 496 0
r 608 496 608 416 0 10.0
w 496 544 528 512 0
w 528 512 704 512 0
r 704 512 704 416 0 10.0
r 288 96 288 144 0 0.1
d 464 432 464 400 1 0.805904783
d 560 432 560 400 1 0.805904783
d 656 432 656 400 1 0.805904783
d 752 432 752 400 1 0.805904783
c 464 368 288 368 0 2.0E-6 19.11028642834088
c 832 368 832 432 0 2.0E-6 0.08410448062336322
w 752 432 832 432 0
c 560 368 624 368 0 2.0E-6 19.21631605388307
g 624 368 624 384 0
r 656 368 656 320 0 1.0
c 656 368 720 368 0 2.0E-6 434.2064460333869
g 720 368 720 384 0
c 288 96 192 96 0 0.001 19.289132336070534
g 192 96 192 128 0
t 416 416 464 416 0 1 -19.11028642834038 4.999999999998019E-13 100.0
t 512 416 560 416 0 1 -19.21631605388257 4.999999999998019E-13 100.0
t 608 416 656 416 0 1 -434.2064460333864 4.999999999998019E-13 100.0
t 704 416 752 416 0 1 0.7325656974601549 0.816670178083518 100.0
r 752 320 752 368 0 1.0
r 464 304 464 368 0 1.0
r 560 320 560 368 0 1.0
w 752 368 832 368 0
o 1 64 0 289 640.0 25.6 0 -1
o 1 64 0 34 1280.0 12.8 1 -1
o 50 64 0 34 1280.0 25.6 2 -1
o 58 64 0 290 20.0 6.4 3 -1
This circuit is a gift for your research.
If you feel by any chance thankful and want to repay please ask me how....
It always cycle the energy between coils and capacitors so it works at very high efficiency or close to unity. The only dissipation is the internal resistance of the components like coil transistor or capacitors and diodes..
This circuit is what is needed for a magnetic field pump for example in the epg.
It could be used in other ways as well. And if you want to add more stages simply add more stages.
Another application could be pulsed motors.
The turn off add on. Its useful to let the energy get back to the source in the case the circuit need to be turned off.
It can be employed with a switch and flyback diodes so pressing this switch allow to disconnect the main switch safely.
Hope you enjoy.
Sebosfato
« Last Edit: November 26, 2013, 14:59:31 pm by sebosfato »
Re: Gift of the day: Capacitive water filter
« Reply #1 on: November 27, 2013, 10:58:23 am »
(http://www.ionizationx.com/index.php?action=dlattach;topic=2791.0;attach=13067;image)
I came up with a simple electric water filter idea.
Its basically two sections of activated carbon pressed in stainless steel tubes which the water pass thru but theres a spacing between the two forming a gap such to have a valve installed for discharging some of the water during the cycles.
During the charging cycle the water is forced from tank A (initial water) to tank B (deionized water) and the water is recirculated between the two tanks passing thru the filter while some voltage is applied to the carbon sections. When the carbon is full of ions a mechanic valve opens and let some water to leak out, flushing out the dirty while the capacitance is discharged. The capacitance can be charged reversely than to help complete discharge of the ions from the carbon sections.
It can be arranged in such way that gravity works helping some of the tank B water leak back cleaning the lower portion of active carbon.
A polymeric filter can be used in combination.
Yes with the water being constantly purified its easier to get to apply higher voltage to it.
As the carbon has a gigantic active area the capacitance become giant and thus many charges get trapped by the filtering. Getting charges busy seem a good way to allow high voltage application.
If you feel thankful and want to repay please let me know.
« Last Edit: November 27, 2013, 11:19:51 am by sebosfato »
Re: Gift of the day: Sequential Pulse generator
« Reply #2 on: November 27, 2013, 11:59:25 am »
hey fabio this is for making deionized water...
