copy from Russ's forum.
http://open-source-energy.org/forum/showthread.php?tid=1424&page=3i said word "brown gas is powerful than hydrogen(h2)" then i try to figure it out,and what gas is more energy than hydrogen?
1.mass=18.042.dont know the name.
2.mass=1.hydrogen1,not h2.
search wiki,energy level.if atom has lowest energy level it will stable,that mean if it has more energy level then it don't stable and more powerful when ignite.
gas has highest energy level,much more than liquid or solid.lowerst energy level is solid.
atom has higher energy level than molecule.atom try to stable then it find another atom to make it to stable state(lower energy level)=molecule or covalent bond.
then you known the answer=H1.
if you ionize H1 to H1+ then it must powerful than normal H1.High voltage and gas processor,all this things to make it powerful than normal.Ionization it to highest energy level.
why stan use high pressure?gas atom when you compress it will be hot,this hot will go to h2-->h1=higher energy level and not stable same concept of air condition,to compress gas.
why liquid gasoline cant ignite?it can ignite when it is a vapor!!!why?higher energy level.
all best.
thanks
geenee
