Forum for alternative environment friendly technology research
Home
Help
Login
Register
A green and clean environment is a human right!
Projects by members
Projects by members
Sebosfato
(Moderator: Login to see usernames) »
The Fracture cell
Print
Pages:
1
Go Down
Author
Topic: The Fracture cell (Read 2580 times)
Global Moderator
Hero member
The Fracture cell
on:
April 05, 2013, 13:55:53 pm »
I think i got a solution to make the fracture cell works... For those who tried or want to try may be of concern!
This patent mention meyer inability to restrict the amps and need complicated methods there to achieve that...
Basicaly consists of a plastic cell where an ac electric field supose to break the water by colision...
The problem is the patent don't show something that works but i guess i found what is the problem.
The problem is that in the circuit provided in the patent the capacitances get permanently charged so they block each other...
I found out thinking about it that if we use a bifilar coil connected across each phase with a diode foward biased to it you not only create a the discharge path but this will reverse the voltage perfectly at the moment where the other pulse from the other phase beats!@
holly @#$$$%
It become a resonant tank! so little consumption is expected..
Logged
Global Moderator
Hero member
Re: The Fracture cell
Reply #1 on:
April 05, 2013, 13:59:16 pm »
I think thats why they proppose that kind of signal for controling it, i mean the duty cycle control and the separation between the pulses...
To mention a few the transformers are arranged as flyback..
Last Edit: April 05, 2013, 15:28:20 pm by sebosfato
Logged
Global Moderator
Hero member
Reply #2 on:
April 05, 2013, 22:55:07 pm »
If i'm not wrong than the electric fields will be in quadrature so theres going to be AC sharpy electric fields than moments of 0 electric field between the pulses...
Logged
Global Moderator
Hero member
Reply #3 on:
April 06, 2013, 12:46:37 pm »
it shouled look like this
Logged
Administrator
Hero member
Reply #4 on:
April 07, 2013, 09:23:21 am »
Quote from: Login to see usernames on April 06, 2013, 12:46:37 pm
nice stuff from mr eccles..
if i remember, aaron murakami from energetic forum did this with limited succes...
Logged
Global Moderator
Hero member
Reply #5 on:
April 08, 2013, 18:34:12 pm »
well the idea is straightforward, if it just makes hot water than would knew is in the right way, because collision is going on...
Logged
Global Moderator
Hero member
Reply #6 on:
October 23, 2015, 14:43:11 pm »
i´m back on track... the fracture cell theory goes all in agreement with what i came up with... so i´m developing the circuit again but now on pcb
i used a 4017 in back when i tried in 2011 for the divide by two but the wave forms are not exactly the way i wanted,,,
does anyone ever tried?
some one could suggest another way to divide the freq by 2?
Best Regards to all
i´m almost with the money by the way for those who are still willing to help believe its very important still!
to donate
https://www.paypal.com/br/cgi-bin/webscr?cmd=_flow&SESSION=wjuVf9a18kZQ9eWuuzj3c2nzQ4D_hipGv9VRbrmy8tRzbQwtlCyLZunewZ4&dispatch=5885d80a13c0db1f8e263663d3faee8d64ad11bbf4d2a5a1a0d303a50933f9b2
thanks a lot!
Dielectric constant and streght for polycarbonate and acrylic
policarbonate er= 2.9~3.3 40kv/mm
acrylic er=3.5~4.5
Last Edit: February 08, 2016, 07:54:55 am by sebosfato
Logged
Print
Pages:
1
Go Up
Projects by members
Projects by members
Sebosfato
The Fracture cell
