Author Topic: Stanley A Meyer and related work by Jon Abel  (Read 7552 times)
« on: February 23, 2013, 18:02:56 pm »
HHO researcher Jon Abel is reported to have some success in having his electronics produce step charge patterns similar to those of Stanley Meyer
According to Jon, the basic circuit is based on David Lawton's pulse width moduator PWM and circuit of JL Naudin of JLN labs. The desired "shark fin"
oscilloscope traces may be seen as his youtube account and also at russ's rwgresearch  forum.  His tale of obstacles being placed into the path of his research
is discussed both at peswiki and the smartscarecrow show and has an all too familiar ring to it. For the advanced experimenter, the  recent modications to JLN
circuitry combined with a Lawton PWM could be avenue worth pursuing ;)
A link to interview at SmartScarecrow Show
http://www.youtube.com/watch?v=JakH_7Qtb8E&list=PL50AA71162981823D&index=6
A link to Peswiki article
http://pesn.com/2012/06/18/9602112_Volunteer_Jon_Abel_banned_from_NDSU_for_Stanley_Meyers_lab_research/
A link to russ' comments on Abel
http://www.youtube.com/watch?v=2p1D-HIMqF0
A link to jon's site
http://www.youtube.com/user/joabel19711/videos
Video list
jon has flagged most of these links as private now, you will need a password to access
http://www.youtube.com/watch?v=EKG70zfu1l4
http://www.youtube.com/watch?v=kxQj-9aZU-Y
http://www.youtube.com/watch?v=W6AXzE_75RM
http://www.youtube.com/watch?v=EYrkPmyfBZU
http://www.youtube.com/watch?v=JvxvHLh-k5k
https://www.youtube.com/watch?v=cgzLov6nDlQ
https://www.youtube.com/watch?v=TwenfkbDi9Q
http://www.youtube.com/watch?v=LYBBb2Z0cYg
link to plans  ( uses old jnl circuit)
http://smartscarecrow.com/wp-content/uploads/2013/01/MyWFC11.pdf
http://www.youtube.com/watch?v=mh04uELdsNM
link to new circuit mod
http://jnaudin.free.fr/wfcbooster/WFCbooster06en.htm
« Last Edit: February 12, 2021, 12:58:51 pm by jim miller »
Re: Stan Meyer and related work by Jon Abel
« Reply #1 on: June 17, 2013, 02:08:05 am »
The above videos show a classic Stan Meyer type shark fin trace but higher voltage zeners
would likely have handled the peak voltage spikes. The videos show some fine work by fellow
with the electronics training. It is a true shame about  hassles he has experienced
Keep up the good work jon :)
regards
« Last Edit: June 17, 2013, 12:32:48 pm by jim miller »
« Reply #2 on: June 18, 2013, 03:42:23 am »
how do we get a password to watch em.
« Reply #3 on: June 18, 2013, 04:28:29 am »
I believe that jon is a member here at ionizationx   joabel1971   or you could get in touch at his youtube site
perhaps he will give a a password to view them. they are his videos and he can do whatever he wants with them
jon is a very smart fellow and he is definitely on to something :)
« Last Edit: June 19, 2013, 14:19:37 pm by jim miller »
« Reply #4 on: June 21, 2013, 21:46:38 pm »
The step charge can be produced like this with a small ferrite balun made of four feet of stranded wire using typical hyperfast diode and pure RO water, gap at .5 millimeter.
some gas when pure water, much gas with CaOH and very much gas with KOH
KB
« Reply #5 on: June 21, 2013, 23:00:34 pm »
That is a fine o-scope trace kickbackemf. will your circuits support 2400 V spikes across the anode and cathode surfaces
without the electrolytes ( such as distilled or rain water) and not have the diodes breakdown?
nice work
regards
« Reply #6 on: June 23, 2013, 01:10:07 am »
In this case I'm running 16v off a laptop charger and 30 ma across the plates in RO water using an irfbc40 MOSFET and BYW29 diode, using a lm393/555 pwm with a dozen .1uf capacitors in series for the pulses to get in the multi 100k region with control of the pulse width really helps.
Currently doing all my work in the 40 watt area and I have yet to get to 2400 volts or more ptp like I used to at higher watt usage.
KB
Still quacks like electrolysis...
« Reply #7 on: June 23, 2013, 01:30:56 am »
And much credit should be given to Sebosfato for the pll circuit he brought to this forum.  I use it and am thankful that he shared it here.  Using the lm393/555 pwm to gate Sebs pll 4046 pulser makes this waveform simple to produce.  You are looking for positive only waveforms way up past resonance and using only them by chopping off the trailing ocilations with another new pulse, the typically damping off wave is interrupted after first first large positive swing and then just before it gets a chance to swing into negative territory with the rest of the oscillation, you hit it with another positive pulse.
Kb
