Author Topic: How Stanly Powered His alternator  (Read 67542 times)
  • OO-Rah!
« Reply #32 on: April 01, 2008, 21:36:18 pm »
Her is a link to a JOE CELL
http://www.youtube.com/watch?v=A-q6HGmN07o
Spike
« Reply #33 on: April 01, 2008, 23:26:06 pm »
I would like you take  a closer look at the connections of the very early meyer staged demo as it appeared on grove city ohio newspaper thursday oct 25th 1984.
If we can figure out the connections and the alternator set up from this high  respic we may find some more clues. I labelled the wires to the best of my understanding, I would like all of you take a look and add on / correct mistakes.
So I am attaching both pics the original and the edited.
thanks
My Take: I dont see any external diode bridge. The wires seem to neatly bundled with the plastic clips to the WFC.
However there are two power supplies from the mains so one is going to the motor, the other is going to ??
« Reply #34 on: April 02, 2008, 00:04:15 am »
Thats the same alternator and driver motor as in the stan video.
« Reply #35 on: April 02, 2008, 05:18:16 am »
I'm not so sure thats an alternator now, i have spent over an hour looking at the picture and its starting to look like the alternator is a driver motor for the driver motor. i am starting to think he may be generating 3 phase,, just a thought for now...
i will look into all this, and if stevie has the same motor we will see whats on the left hand side of the driver motor....
i can take my 120 volt driver motor and generate 210 volts at well over 5 amps, and it seems strange because the motor doesn't pull down like its in stress.. hrmmm
Tommy
« Reply #36 on: April 02, 2008, 06:53:41 am »
You may be onto something Hydro. I've looked at it off and on for quite a while. It seems way too big for an alternator. It doesn't seem too big to be a small generator head being driven by the driver motor to generate 3 phase.
Also that box and black thermos type thing are on a separate paper from the motor/generator. They are not in the video, and may be something that has nothing to do with the WFC. Just what I see.
« Reply #37 on: April 02, 2008, 09:47:39 am »
Hello!!!!!!!
Wake up, you all!
The Alternator IS a 3 phase generator.
So whats is the point here?
Do you suggest that Stan used 220V 3 phase instead of 30V 3 phase?
« Reply #38 on: April 02, 2008, 10:37:22 am »
i dont know,, my mind is wondering off again,,, hrmmmmm
« Reply #39 on: April 02, 2008, 15:41:59 pm »
Why not?!    I noticed more volts makes more bubbles but amps make loads of heat.  Just one 30V 3phase alternator has enough amperage to boil the waterbath.    Why did Stan's stay cool like everyone said??  What did he do different?
