Author Topic: ionized HHO  (Read 20146 times)
Re: ionized HHO
« Reply #8 on: November 26, 2012, 23:04:27 pm »
Well, after watching this video, I think I need to re-examine my thoughts... What do you think about this video?
https://www.youtube.com/watch?v=foIWltOShO0&feature=r-vrec
Mindblowing......
Thats a smart man....
It seems that we still do not know everything about electrolysis systems.
The test with the plastic cards prove the alpha particles!
Re: ionized HHO
« Reply #9 on: November 26, 2012, 23:18:31 pm »
great from your post, i thought about this.
http://open-source-energy.org/forum/showthread.php?tid=825
then later version of wfc,it is very small.cause that way.ionize+laser to ambient air.
maybe need hho only 4.8 lpm for run 100km/h.
thanks
geenee
10cc is what this fellow researcher needed...
Further, the story is similar. Warm water, ionized water with salt, a pulsed DC voltage at almost 80 volts and 68 amps.
The result is a highly energized HHO gas with steam. Those two components do well in engines...
Re: ionized HHO
« Reply #10 on: November 29, 2012, 22:22:50 pm »
Re: ionized HHO
« Reply #11 on: November 29, 2012, 22:25:53 pm »
The question is how much we want or need to ionize the hydrogen atom.
Accoording to theory,14 volts is the minimum. 20 volts is getting the electron of the hydrogen atom to some higher levels, like n4.
This is the Schrödingers theory.
Re: ionized HHO
« Reply #12 on: November 29, 2012, 22:46:15 pm »
Absorption of ultra-violet radiation
Because bonds between atoms in molecules have varying strengths, it takes different amounts of energy to break them down.  The bond between the two oxygen atoms in an oxygen molecule (O2) is really strong and can only be broken down if the molecule absorbs very high energy UV-C radiation.  The bonds between the oxygen atoms in ozone are a bit weaker and can be broken down by absorption of slightly less energetic UV-B radiation.  Absorption of this highly energetic, short wavelength, radiation by O2 and O3 in the upper atmosphere prevents it reaching the troposphere and destroying O2 and O3 there.  Less energetic radiation (with longer wavelengths) reaches the surface of the Earth.
Re: ionized HHO
« Reply #13 on: November 29, 2012, 22:47:45 pm »
Re: ionized HHO
« Reply #14 on: November 29, 2012, 23:18:59 pm »
http://www.spartanwatertreatment.com/UV-ozone-destruction.html
I like that link...  if you havent been to my old yahoo group -Hydroxy Boost- which is now - water4gas-   long story but i gave hydroxy boost away and then Earl changed its name to water4gas... but any way i think you would find alot of interesting files and links posted by me (burnhydroxy) on there.. or ill go and see if there is anything saved there that mite perk ur interests as well :)
Re: ionized HHO
« Reply #15 on: November 30, 2012, 08:45:22 am »
Hi Newguy,
It seems that you know your way at the water4gas site....
I might suggest you copy the interesting parts to here, somewhere.
I really appreciate your interest in this topic. There is much to gain in this subject.
More then most people think, from my point of view....
