Wow great info... could you explain a little further?
I'm working on some numbers. I'll expand further when I can. I was a little puzzled when my first step up locked in at 500Hz and expected the 20:1 to lock in with a higher frequency. Even though it is still scanning with a frequency in the kHz range, the lock in frequency when probing the cell was still only 11Hz.
TS
In a way, it actually makes sense. Since it it will take longer to charge and discharge a larger secondary than a smaller one.
Actually, I was in error. I was forgetting the fact the LC is tuned to resonance based on capacitor and inductor values. Obviously, by the size of my cell, the higher number of turns I have done on my secondary necessitate a lower resonant frequency. If I want a higher frequency, I need to lower the number of turns appropriately to match the capacitance of my cell.
That means I need a smaller secondary and even smaller primary if I want to step up the voltage.
TS
