Author Topic: What I'm Doing today.  (Read 2923 times)
« on: September 09, 2012, 00:43:20 am »
You can follow me here as I post, IF I decide to post. I will post here what I am reading on today if I feel like posting.
This is only for those that is interested in where I am looking for information at. Today I am looking at this because I feel it is very important. I am curiouse about diodes because I know soon there will be a great demand for one in this type of technology. Perhaps A coil could replace a Diode, I do not know thats why I'm reading about it.
http://www.google.com/imgres?hl=en&safe=off&sa=X&tbm=isch&prmd=imvns&tbnid=CbIKD8EDobliBM:&imgrefurl=http://www.ledtuning.nl/gallery/history/GalenaDetector_EN.php&docid=dhpzPDxG6H7QHM&imgurl=http://www.ledtuning.nl/gallery/history/GalenaDetector.jpg&w=640&h=480&ei=wshLUKioFoqY8gTqi4DQDw&zoom=1&iact=hc&vpx=939&vpy=370&dur=619&hovh=194&hovw=259&tx=142&ty=177&sig=100630796873521825392&page=1&tbnh=147&tbnw=205&start=0&ndsp=15&ved=1t:429,r:14,s:0,i:120&biw=1239&bih=678
Re: What I'm Doing today.
« Reply #1 on: September 09, 2012, 00:46:14 am »
Good reading here http://www.electronicstheory.com/COURSES/projnkits/projDiode.htm
Here I'm trying to figure out how to dope my own diodes http://electronics.howstuffworks.com/diode1.htm
Here I'm Learning how to get Silocon http://en.wikipedia.org/wiki/Silicon
This seemed to help me understand Silicon http://www.ehow.com/info_8675759_uses-metalloids-industry.html
I took the 30kv 2 amp diode I blown up and put it into the lath. I turned it down to 1/4" and there was nothing there accept a black substance that never seemed to change from the time I started turning till the time I ended. I did notice a series of about 20 copper wires 1.5mm in diameter spaced about 1/8" apart. There were some along the left side and some along the right like a checkerdboard. on one side you could tell that the material surrounded the copper about .7mm all the way around the copper as if it was seated in a slightly darker dope. The other side looked normal. It sorta looked like you was looking at a catapilliar upside down, and on his left legs they all had rings around them. I dont like playing with arsenic so I made it a fast note.
« Last Edit: September 09, 2012, 01:50:37 am by Hydrocars »
