Author Topic: THE V.I.C.  (Read 35091 times)
Re: THE V.I.C.
« Reply #48 on: December 05, 2012, 02:39:11 am »
So I see in the video posted at the top of the page, that someone was able to replicate the same signal that I have gotten with my replication of Stan's VIC Circuit and transformer....Very Nice!!!
The photo I have attached was take on 8/18/2008 using my prototype VIC  ;)
-Tony Woodside
http://www.GlobalKast.com
« Last Edit: December 05, 2012, 03:35:26 am by TonyWoodside »
Re: THE V.I.C.
« Reply #49 on: December 05, 2012, 18:44:58 pm »
Tony, What method did you use to find the capacitance of your cell or cells?
Re: THE V.I.C.
« Reply #50 on: December 05, 2012, 23:09:00 pm »
,webmug,what was the voltage over the wfc before you hit resonance?
Re: THE V.I.C.
« Reply #51 on: December 06, 2012, 11:35:35 am »
The scope-shots are at the chokes output B+ and B-.
One exciter plate was connected to choke B+ and you see frequency shifting and voltage amplitude dropping.
This also was seen at B-.
Voltage over wfc was AC at resonance and about 60V. No production!!!
Regards
Re: THE V.I.C.
« Reply #52 on: December 06, 2012, 13:07:22 pm »
Thanks webmug,thats the most frustrating thing,you painstakingly wind 10000turns and in the end you get 10v across the cell...Good luck with your experiments!
Re: THE V.I.C.
« Reply #53 on: December 06, 2012, 13:12:52 pm »
How do you measure across the cell without introducing a new resistance path?  Additionally, because of a resistance path on the VIC at the cell, you lose your voltage.  Ever try measuring the voltage on a battery powered bug zapper?  Even though it uses high voltage to zap, if you put your probes on it it doesn't reach it's peak voltage due to leakage across the probes.  Best you get is a few volts.
TS
Re: THE V.I.C.
« Reply #54 on: December 06, 2012, 13:15:56 pm »
Hello check this out... http://www.youtube.com/watch?v=NczhXYkK0BI&feature=player_embedded#!
I have similar wave forms.  But this is an awesome tutorial on how to get there.  Read his comments below the video.
TS
Re: THE V.I.C.
« Reply #55 on: December 06, 2012, 13:28:05 pm »
read it all,so it all..nothing works,i damaged my vic a while back so i only have scrap wire ,lawton pwm,9xb,and coils,non of my experiments show high volts acros wfc,i put various resistors on one side of the wfc,on both sides,isolated the cathode,put distiled water,vary the capacitance of the cell,NOTHING WORKED,i dont know what else to do.Have anyone had any succes with JL Naudin's setup?i tried his setup and again,the frickin voltage drop.How an earth do you get the volts up?
