Its seems to be the way... As we only use the force of the field and not the amps..
Well i think, and notice this is my personal belief, that thicker coils will have a higher electric field induced at the leads for the same potential and length because i think there will be more free charges to be disturbed by the EM fields... and the surface of the wire does not increase much...
Thats why today instead of start testing my vic, i constructed a new one with thicker and less turns wires.. 100 turns each choke 18awg, 30 primary 18awg, 200 plus taps the secondary probably 28awg... one over the other respectively so i can adjust the secondary...
I wound the chokes first, isolated from each other, than a cut another bigger bobbing and fit it in the outside of the first bobbin cavity, there i wound the primary, and than the secondary... all same polarities are at one side of the bobbin...
I can use for this new vic 4 configurations of core, CC,CI,I,CIC
i'm going to finish all the setup later for start testing it...
