Author Topic: Electrolysis101PDF Download  (Read 6965 times)
« on: August 05, 2012, 10:37:56 am »
I wasn't ready to share this because it's nowhere near finished, But anyways have a look at it until I finish it.
« Last Edit: August 05, 2012, 11:33:39 am by Hydrocars »
Re: Electrolysis101PDF Download
« Reply #1 on: August 09, 2012, 21:47:10 pm »
No comments?
(OH I KNOW THAT)
And the carbon element reveals itself!>
It helps, it isn't pure but its 90% the container is the size of a golf ball.
« Last Edit: August 09, 2012, 22:08:41 pm by Hydrocars »
« Reply #2 on: August 09, 2012, 22:10:12 pm »
Imagine a cup full of gas taking you 1000 miles. Same post can be found http://open-source-energy.org/forum/showthread.php?tid=669 and I posted our link there as well.
This is what the technology had to offer, this is what its about! The videos arent fake they just dont show everything. Now look in the right places and face the facts, Start piecing it together and get it finished! From here you'll have to use your mind to draw the schematics, its not on paper but there are paper trails, small ones. There is a paper trail in the video as well. Anyone with a mechanical mind can take this information and put it to work. Its similar to a geet but the geet doesn't quite cut it.
A new synthetic fuel is born!
« Last Edit: August 09, 2012, 22:37:09 pm by Hydrocars »
« Reply #3 on: August 10, 2012, 00:03:23 am »
where did you extracted that? from the video where the buggy was iddling in the driveway?And what's happening if you bubble the hidrogen trough gasoline?
« Reply #4 on: August 10, 2012, 00:47:40 am »
That was extracted from that video yes. When you do so it runs, The goal was to use water instead of petrol, the secret was closely guarded and shunted to a stand still with you know what! Stans goal was to reduce petrol consumption by over 75% using this system.
The element Hydrogen is used in rockets, we are after a synthetic fuel that contains Hydrocarbons which is what the synthetic fuel produces.
You need more than the hydrogen element, you need carbon as well and as I said in the PDF, Carbon Reactors can last for very long times, 3+ years in some cases. Stan was using petrol to produce a synthetic gas, I am unsure of the gas because I'm unsure how many carbon atoms bonds with the hydrogen when the Hydroxy gas is passed threw the Carbonated reactor. ;)
Sorry If I popped anyones bubble here, But you'll get over it and get with it. Did you miss the parts where you can add a steady flow of air to the generators to increase gas output?
The car was running off of a ("Hydrocarbon") gas, but what kind of hydrocarbon gas is the question.
To everyone; Please think before you bash, I will not post nothing else if that happens.
« Last Edit: August 10, 2012, 10:42:39 am by Steve »
« Reply #5 on: August 10, 2012, 10:04:55 am »
Hi Brian,
Thanks for the document. Appreciate your effort on that.
I can remember us trying to follow the HHO tube into the bug.
So, you think he used a petrol filled bubler?
Meaning, he used petrol vapour with HHO?
Sure it will save a lot of petrol and indead you will get carbons in the combustion cycle.
I think it might be very plausible.
CAn you pinpoint the time for me in the video on where you seen that bubler?
« Reply #6 on: August 10, 2012, 19:44:17 pm »
Stan was ask about it in one of his lectures on one of those cd's you sent at the end of the speach, there where a class full of audience, I dont recall which one. Also, it is seen but I cant put my finger on it. I dont thing you can see it in that particular video. It may have been a newspaper article, Im not certain. I know if you did you will find it.
« Reply #7 on: August 11, 2012, 00:21:44 am »
Hi Brian,
No I dont "Think" he used the petrol bubbler.  ("I know he did.") The technology could only be used on pure water when he stored the hydrogen, gas on demand used the bubbler. Stan told you to introduce Ambient air and exhaust gases into the generator, I have that in my pdf as well. You need to use an air pump at a regulated flow depending on the production. Ambient air and CO2 makes no difference, They both support full combustion while using nothing causes incomplete combustion of the hydroxy flame which is why the flame is orange in color. Lye further causes incomplete combustion but by adding ambient air it can be tuned to a more complete combustion to the point it can be so clean the flame can go out.
We already know that we can (Create) Lye using electrolysis without having to actually add it into the water. We also have chlorine to boot. Proof of chlorine can be seen by using a DIE in the water, then using a Lye to revive it. Too much to point my finger at here.
Much has been overlooked and hidden away, but it cant be hid forever!!!
I'm sure stans goal was 100% water, But what we witnessed in that one video where the tank was in the grass, He was borrowing the carbon atom from the (Golf ball sized Anti Splash Resovor.)
Gases contain Carbon, They're hydrocarbon gases and stans bug was running on a hydrocarbon gas mix he called a (Synthetic fuel.) Synthetic means man made and those exact words are also found in one of stans patent, I think the patent can be found in my last pdf posted on the 3 phase rotoray conversion process where he used 3 phase electrical current onboard the bug. Too bad he did not have a Digital Power inverter back then ehh,,, would've saved him lots of time. It doesn't matter how its produced as long as you mix it properly.
It will run on water, not 100% water but damn close! Stan did have it run 100% on water but, he could not go very far! The rest is hogwash.
