Author Topic: UFO Politics Motor Generator replication  (Read 6570 times)
« on: July 22, 2012, 05:08:55 am »
I'm going to publish here my replication progress of the asymmetric motors ufo politics presented at the energetic forum.
I bought three permanent magnet dc motors 0,5HP for this project... rated 97V 5A 1700RPM
His idea is nice, to use the BEMF to favor the rotation generating at the same time electricity. He stated that he can run a generator with this motor and the generator is this exact motor just used as generator and generate 150% the input power in electrical energy.
Here a video:
http://www.youtube.com/watch?v=Mj4rV0AoI-Q
I will destruct one of the motors to get its brushes installed into another that will end up with two collector, brushes sets---
This brushes has 18 positions so initially i will short each 6 of them... to start with only 3 coils for testing...
I'm going to use his three pole configuration as 18 poles is multiple of 3.
« Last Edit: July 22, 2012, 17:18:16 pm by sebosfato »
UFO Politics Motor Generator replication Great news!
« Reply #1 on: July 25, 2012, 17:35:31 pm »
Great news
I found a way to make the modification pretty easy without changing the shaft length and without changing the body of the engine at all.
I extracted the collector from another motor, and it will be located outside the body at the other side relative to the original collector at the motor. Under the bearings i will made cuts in the shaft where the wires will pass thru and directly come out of the motor where the collector will be. The space will be somewhat critical but might work. I could even use the shaft as one of the connections...
All the work must be done at thinking of the center axis of rotation to keep it aligned.
My outside collector will be than fixed by a nut into a screw axis coming from the center axis of the shaft.. Thus i can change the angles if required...
A mechanical friend who helped me with this idea is going to make the cuts with a milling machine in the shaft for me and the adaptor for the collector with a mechanical lathe...
Re: UFO Politics Motor Generator replication Great news!
« Reply #2 on: July 26, 2012, 00:36:56 am »
Great news
Good luck, dude!
« Reply #3 on: July 28, 2012, 09:44:45 am »
Hello,
The motor-generator-transformer, is almost ready! I just need to make some final adjusts and think well how i'm going to wind the wire.
I talked to UFO yesterday and seems that he meant that the greater is the time the coil travels without being connected to anything the more it will "capture" "radiant energy".
The idea behind this thing i believe to be somewhat related if not completely related to this patent: http://www.rexresearch.com/alxandr/3913004.pdf
It somehow describes what UFO describes, a motor that acts as a transformer and generator while the generation and transforming actions assist the rotation instead of causing counter force on the rotation.
Later i'm going to put here some images of the modification details.
For now notice the similarity of this Alexander patent, and tesla patent drawings at the first post...
Both have a set of commutator and a pair of slip rings interconnected!
UFO Politics Motor Generator replication, Modified motor!
« Reply #4 on: July 29, 2012, 22:15:43 pm »
Here some pictures...
Here you see how the brushes are fit inside and outside the motor
The details of the cuts on the shaft coming out the motor to pass the windings thru them...
