Author Topic: Back and Forth  (Read 1358 times)
Back and Forth
« on: July 10, 2012, 18:42:31 pm »
I had an idea of how to measure the back and forth frequency of the water...
The idea is simple... It consists in an electrolytic cell having two parallel plates gap variable, having special made coil around the cell. The coil will capture the magnetic field derived from the ions movement. A square wave is applied to the cell and the voltage reading across the coil could be interpreted as the ions movement. As the ions are positive and negative they should create a magnetic field that adds up since they are accelerated in different directions. The output wave form will tell about the ions movement if not also extract energy from the electric field itself...
The ions will have a certain speed limit just like a skydiver have limit speed. So the results could become contradicting as constantly moving ions only create magnetic field that is not varying except by its motion! However is a start point.
The analysis must be focused on the electric field force and ion charge mass relation and water density.
Motion can be implemented externally so easy measurements can be done.
The coil could be done following the electric field and when it need to return against the magnetic field it should be more perpendicular... This will raise the chance to capture a signal.
« Last Edit: July 10, 2012, 19:56:26 pm by sebosfato »
Re: Back and Forth
« Reply #1 on: July 10, 2012, 20:15:02 pm »
Another thing that could be done. To try understanding more about the ions mobility would be to measure the current density for a given voltages the gas generated and the temperature rise. The difference between gas generated and the energy dissipated at the resistance will be the current * the over voltage and electrolysis potential.
