Author Topic: Ionizationx Alternator Schematic rotor pulse  (Read 16798 times)
Re: Ionizationx Alternator Schematic rotor pulse
« Reply #24 on: May 18, 2008, 17:28:42 pm »
Hi Voltar,
Any alternator will work.
Just put some power on the rotor and rotate the rotor with help of a driver motor and you are on yr way!
But you cant leave the voltage regulator in it cuz it will make it a single phase... right?
« Reply #25 on: May 18, 2008, 23:56:21 pm »
Hi Voltar,
The output of a standard alternator is rectified DC.
If you remove the diodes, then you will see the three phases
Voltar X
« Reply #26 on: May 19, 2008, 02:34:48 am »
Thanks Stevie...will be hooking up a direct-drive donut between the motor and the alternator. Motor runs at 3250 rpm. Wanted to try this instead of using a belt.  Any words about the Boyce pwm? I'm planning on having it modified so it can handle higher input/output d.c. and then send it to the alternator..which you'll love when you see it. Beautiful custom chrome-job. Hey, I want my unit to not only work great but it's gotta have some bling! LOL!
Thanks again, guys.
« Reply #27 on: May 19, 2008, 21:28:30 pm »
I have been lurking for a while. I will like to provide an  input.
I think you have the right collection of components: alternator and motor.
What is missing is a signal generator to modulate the RF and a choke. Go back and read fearjars report at waterfuelcell.org.
The replication, according to fearjar is transient . The variables have to be constantly adjusted to sustain the effect.
Dave Lawton used his pwm to control the alternator frequency.
« Reply #28 on: May 20, 2008, 01:18:46 am »
just to make things clear,, this is not a stan replica. this circuit pulses the maximum amount of amps into a cell with no form of amp restriction.
