Author Topic: Example of Stan's VIC Transformer with 180* Phase Shift  (Read 13307 times)
« on: February 22, 2012, 00:02:23 am »
in this video I show an example and explanation of how Stan's VIC Transformer operates.
http://www.youtube.com/watch?v=nuHgc3Xtgog
Re: Example of Stan's VIC Transformer with 180* Phase Shift
« Reply #1 on: February 22, 2012, 00:30:38 am »
Looks good to me! Thank you!
« Reply #2 on: February 22, 2012, 00:56:12 am »
I just made a couple of changes to the setup in this video and here are the current measurements. I added two 220 ohms 5W resistors to the primary, one resistor on each side to limit the primary current. I took a current measurement on the primary with 120VAC RMS @ 60Hz and the current was 72mA through the primary. I also took a current reading on the secondary side of the transformer before the diode and measured 128mA with 25VAC @ 60Hz. I then took a current measurement between the diode and L1 choke and it measured 105mA with 10.5VDC @ 120Hz. Also took a current measurement on between the secondary and L2 and it measured 128mA with 25VAC @ 60Hz. The transformer is a 21:1 set-down. I get a nice stream of HHO and I let it run for 20 mins and the water temp hasn't increased at all.
« Reply #3 on: February 22, 2012, 03:27:48 am »
very nice, works just like you said. and just like stan said more that matter. My question is, have you gotten it to work with your vic setup. Does the higher frequency cause a problem?
« Reply #4 on: February 22, 2012, 06:12:58 am »
So in this setup I take it your applying AC to the AC XMFR?
Do you think the secondary coil is supposed to be center tapped?
Attached is a multisim replication to show the doubling effect so everyone can see what Tony has done in the video!
« Last Edit: February 22, 2012, 07:46:11 am by HMS-776 »
« Reply #5 on: February 22, 2012, 09:12:38 am »
thats correct...the reason I used the center tap is because the VIC Trans acts like center tap trans. In Stan's trans you want your reference point to be between the Secondary and L2 (negative) choke and you should see this same effect.
« Reply #6 on: February 22, 2012, 14:14:11 pm »
What are the specs on the vic - bifilar or not?
Wound in the same direction - different direction - # of turns?
« Reply #7 on: February 22, 2012, 16:39:51 pm »
I tried doing what you have suggested. I seems i'm not getting any rectification from the diode.
Any idea why?
