Author Topic: VIC setup 2  (Read 4717 times)
VIC setup 2
« on: January 01, 2012, 12:29:48 pm »
I got this core that I plan to use for the VIC. This is a big core , one of the largest they have from Ferroxcube. Hope specs will be close to the specs provided by dynadon.
Re: VIC setup 2
« Reply #1 on: January 01, 2012, 13:29:03 pm »
yesterday I wound this thing with 30awg (0.25mm) wire
625 turns for primary
3500 turns for secondary + centertap @ 1750turns(center)
3500 turns for L1 and L2 chokes (also tapped L2 @ 3303 turns [ratio 12th root of 2]
extra auxilary coil with 1500turns
Re: VIC setup 2
« Reply #2 on: January 03, 2012, 09:48:56 am »
Some extra pics
Re: VIC setup 2
« Reply #3 on: January 03, 2012, 13:03:14 pm »
Fantastic stuff HM!
Re: VIC setup 2
« Reply #4 on: January 04, 2012, 08:31:43 am »
Thanks Steve.
Re: VIC setup 2
« Reply #5 on: January 04, 2012, 08:33:47 am »
As for the resistance and inductance values for each coil, this is what I came up with:
primary:      10.98H 25ohms
secondary:   28.5H 192ohms
chokes:        aprox 28H 172ohms (each)
for me these look quite high values when compared to Stans. Maybe because of the flatter core he used resulting in less inductance and resistance.
Re: VIC setup 2
« Reply #6 on: January 04, 2012, 09:29:19 am »
Hydrogen mask,
I think your values are very big, try using a gap on the core... next time try winding all coils in the same bobbin, one over the other... this maximize the coupling (less turns needed)... be careful, this high voltage is very dangerous... in your design you will see a lot of sparks if all goes well.
Re: VIC setup 2
« Reply #7 on: January 04, 2012, 11:24:31 am »
On one of your pictures i saw you use a 3C90 core, that has a very high permabillity and thus you get your high inductance values.
