Author Topic: New Meyer video posted  (Read 13240 times)
« on: December 01, 2011, 00:53:34 am »
I just finished uploading a new unseen before video of Stan and his brother Steve testing the VIC system and testing the engine.This is only 30 minutes of the whole video.I will be uploading the rest when I'm sure this one worked first.It may take a little while before the video is ready,but here's the link to it.
Enjoy,Don
There will be 3 parts in all
« Last Edit: December 02, 2011, 03:48:22 am by Dynodon »
Re: New Meyer video posted
« Reply #1 on: December 02, 2011, 01:16:34 am »
Here it is everyone,I have 2 more parts to upload.Another 30 minutes and a 4 minute.
enjoy
http://youtu.be/F-FgsE7s4YY
« Last Edit: December 02, 2011, 03:50:58 am by Dynodon »
« Reply #2 on: December 02, 2011, 03:27:22 am »
Part 2 is now up,check it out
http://youtu.be/xPeQV153GPo
Part 3
http://youtu.be/2x90XqjIK6g
« Last Edit: December 02, 2011, 03:51:39 am by Dynodon »
« Reply #3 on: December 02, 2011, 09:07:44 am »
Thanks for the videos, am recombining them into 1 video for my own perusal.
initial thoughts: Stan was doing several things; firstly converting a carburetted engine to use gas from a cell, converting points based ignition to electronic, and later it appeared to be making the basics of an ecu to retrofit a carburettored engine to injectors.
Im interested in the injectors, i can see that his initial design was designed for that motor that did not have injection already;and was creating the timing for the injectors. So nowdays engines I see already have whats needed - the throttle position sensors and air flow meters, injectors, electronic timing and ecu monitored engine rpm - for primary measurements to control injector timing and spark timing - so a question is - is there a simple way of retrofitting an existing injected vehicle without reinventing the wheel?
« Last Edit: December 02, 2011, 09:24:05 am by wfchobby »
« Reply #4 on: December 02, 2011, 20:31:51 pm »
Thank you Don!
« Reply #5 on: December 02, 2011, 22:52:14 pm »
 Thank You Don, that has satisfied a long craving :) at 1:13 in the second video.... hope'n to understand that part.
« Reply #6 on: December 02, 2011, 23:41:04 pm »
I put all the parts together, so heres the full length video.
http://www.youtube.com/watch?v=5i7znsBJwws
« Reply #7 on: December 03, 2011, 06:29:11 am »
one thing about the injection system is that it is totally obsolete now since fuel injection came out in the mid to late 80's. You can simple "piggy back" the current fuel injection system and let the cars CPU control the injection pulse.
