Author Topic: Pulsed or strait DC electrolysis  (Read 12140 times)
« on: July 22, 2011, 13:17:36 pm »
Here a nice explanation of Les Banki about the difference between strait dc and pulsed electrolysis:
I suggest we clean up this mess.
I have already taken the first step by replacing ‘HHO’ with HydrOxy in all my articles.
Why?
Because the gas my set-up produces is NOT pure mono-atomic H+H+O but a combination of di-atomic and mono-atomic, H2 + O2 + H + O.
As everyone knows, water is: H2O
When split with DC current electrolysis, the gas is: H2 + O2
(Note that the devolved gases are in their di-atomic state ONLY.)
This gas has the LOWEST energy level.
(About ¼ (25%) of the pure mono-atomic H+H+O.)
With PULSED DC electrolysis, we get “Brown’s Gas” or HydrOxy,
H2 + O2 + H + O, (di-atomic plus some mono-atomic gas.)
Its energy level varies with the ratio of di-atomic/mono-atomic gases but usually will be about twice (2X) the energy level of the H2 + O2 gas which is created with DC current.
With RESONANCE (NOT electrolysis!), we should get ‘pure’ HHO (H+H+O).
It has the HIGHEST energy level.
About 4X more than H2 + O2 (using DC current)
The importance of this should be obvious.
If not, let me illustrate it with a practical example which everyone can understand.
Let’s look at two (2) experimenters: “A” and “B”
Their set-ups are IDENTICAL, with ONE exception.
Their electrolyzers (and the power supplies powering them) are DIFFERENT.
But they produce the SAME volume of gas.
Here comes the “weird” bit.
Experimenter “A” runs his generator 100% on WATER.
PLUS other load.
Experimenter “B” needs to ADD hydrocarbon fuel.  He does not have ‘enough’ gas!
But, I repeat, they have the SAME VOLUME of gas!
So what is different?
“B” is using a LOW VOLTAGE, HIGH CURRENT DC POWER SUPPLY to power his electrolyzer.
Further, he has just a few cells in series, then, groups of these are in parallel.
That combination produces only H2 and O2 , di-atomic (molecular) gases!
“A” has a large number of cells in SERIES and uses HIGH VOLTAGE PULSED DC
power supply.
His set-up produces H2 + O2 + H + O (di-atomic plus some mono-atomic gas).
From my short article titled “Running series cell electrolyzers on 50/60 Hz AC power”, here is a quote:
“It needs to be pointed out that in order to make QUALITY gas (HHO, Hydroxy, Brown’s Gas, etc.), PULSING is necessary.
George Wiseman has also pointed this out in his “Brown’s Gas Book Two” which he published many years ago.
Quote (from page 18):
“Power supply considerations
If we apply straight DC current to the electrolyzer, we find the oxygen and hydrogen devolving to their di-atomic state.  We get NO Brown’s Gas.
The electricity MUST be pulsed to an electrolyzer to produce Brown’s Gas; 120 cps is sufficient to produce Brown’s Gas, even 100 cps will work; so regular wall cycles will work.”
End quote.”
So, the ‘bottom line’ is: the HIGHER the mono-atomic (H+H+O) portion of the gas, the LESS the engine will need to run.
I wish to stress, once again, this is NOT a “fairy tale” story.
Over the years, several experimenters have found it to be correct.
There are two main requirements for running engines on water ONLY:
1.  Quality gas (a portion of it MUST be mono-atomic, H+H+O)
2.  Engine management
If these are ignored (or compromised), it is most unlikely that you will succeed in running engines 100% on water.
Instead, you will end up with a fancy “booster”.
This also explains why so few in the past have succeeded using water as the only fuel.
OK.
If you have problems accepting the above explanation, I suggest you watch the video with Oliver & Valentin again.  Closely.
Pay attention to their cell AND its power supply on the trolley.
What do you see??
A LARGE capacity VARIAC (AC mains supply).
On its moving arm you see a heath sink (probably for the rectifier power diodes).
Next to the VARIAC is what looks like a power resistor bar (current limiter?).
Even without knowing all the details of their set-up, we can safely conclude that it is an un-filtered HV power supply, PULSING at 100Hz.  (twice the mains frequency)
IMO, that is one of the 3 reasons why they have a looped, running system with excess power.
The second is their SERIES cell.  (Anton cell)
The third is IGNITION TIMING.
A bit crude but it works.
Best regards,
Les Banki
Re: Pulsed or strait DC electrolysis
« Reply #1 on: August 11, 2012, 14:02:34 pm »
The difference between electrolysis and brown gas is remarkable. The faraday electrolysis using filtered DC or battery, and separates the water into H2 and O2. The brown gas instead is just an single molecule generated between the interaction of oxygen and hydrogen, simplifying is water in the gaseous state; this interaction is due to the vibrational state of stress to which they are subjected atoms of oxygen and hydrogen during their formation within the electrolytic cell. This "vibration" can be created mechanically or electronically, I prefer the latter because it simplifies the design of the cell. The PWM that are now for sale on the internet, ebay, etc. are derived for use on electric motors and do not work to produce brown gas as they use high frequencies and have only one pulsed output. The cells on the market whether WET or DRY cell have significant structural problems and safety as a slight back pressure tends to "open" the seals with the consequent release of gas and water with electrolyte. It is therefore necessary to work first to the creation of a cell safe and specific for the gas formation of brown gas.
« Last Edit: August 11, 2012, 16:32:59 pm by tutanka »
« Reply #2 on: August 14, 2012, 00:31:32 am »
# Introduction: It is possible to generate hydrogen by conventional DC water electrolysis, but this is undesirable for enviromental reasons if the electrical energy for the electrolysis is produced in thermal power stations from fossil fuel because of the generation of carbon dioxide. Fuel cells are promising and various systems are being studied worldwide. The generation of carbon dioxide during hydrogen generation through natural gas for fuel cells can be reduced compared with thermal power stations, but carbon dioxide is still generated. Hydrogen generation by photo-catalysis is preferable but the process efficiency is still very low for practical applications.
Recently, water electrolysis has been reconsidered as a promising method for hydrogen generation since the cost of electricity is decreasing, mainly as a result of wind-generated power. Hydroelectricity and nuclear power can be also used for water electrolysis without generation of carbon dioxide. Even though the electricity cost is falling, it is known that the plant cost for water electrolysis by DC power still dominates a large part of the hydrogen production cost. It is therefore desirable to find a new method of generating hydrogen from water at lower cost. In the present work, we have examined for the first time the applicability of an ultra-short-pulse power supply for water electrolysis.
# Principle: In the conventional DC electrolysis of water, hydrogen is generated as a result of electron transfer from the cathode electrode to adsorbed hydrogen ions on the electrode surface. This electrolysis occurs when the applied voltage between the anode and the cathode exceeds the water decomposition voltage of about 1.6V, the sum of the theoretical decomposition voltage of 1.23V at room temperature and the overvoltage of about 0.4V depending on electrode materials and other factors[1]. DC electrolysis is a diffusion limited process and the current flow in water is determined by the diffusion coefficient of ions. It is therefore difficult to increase the input power for a constant volume electrochemical cell without reduction in electrolysis efficiency.
We have applied an ultra-short pulsed power supply based on a static induction thyristor (SIThy), invented by Nishizawa et al. [2,3] and developed by Shimizu et al. [4,5], and an inductive energy storage (IES) circuit invented and developed by Iida et al. [6,7] and applied in several ways by Jiang et al. [8]. SIThys are Si devices with special structures for high power pulse generation and IES circuits are small-scaled circuits based on induction storage instead of conventional capacitor storage in order to use SIThys. We have applied SI thyristors developed in our laboratory to water electrolysis and found that water electrolysis occurs by a different mechanism from the conventional DC one.
When the ultra-short pulse voltage of less than seceral microseconds is applied to a water electrolysis bath, the voltage application is so fast neither the electric double layer nor the diffusion layer can be stably formed in the vicinity of electrodes.
The pulse width which is necessary for electrolysis without formation of the diffusion layer is estimated [9] to be:
Del.t<(1/4D).(Xad/X)2 (1)
Here, Del.t is the pulse width (s), D the diffusion coefficient (cm2 s-1), Xad the density of hydrogen ions on the cathode electrode (cm-2) and X (cm-3) is the concentration of hydrogen ions in the solution. This equation was simply calculated under the assumption that the total amount of adsorbed ions, Xad, is equal to the diffusion layer thickness d (cm) multiplied by X, and d must be larger than the diffusion length (4D Delt.t)1/2 during the pulse application, considering that the pulse application duration must be shorter than the time necessary to fill the diffusion layer with hydrogen ions. From this equation, taking as D=2.3x10-5 cm2 s-1 for proton diffusion coefficient [1], X=6x1020 cm-3 for 1M for KOH solution and Xad=1015 cm-2 for platinum metal surface, the pulse width is estimated to be about 3 microsecond. This means that electrolysis occurs without forming the diffusion layer in the present work since the pulse width is one tenth of this critical 3 microsec.. It is also known that the time necessary for the formation of the stable electrical double layer is of the order of several tens of milliseconds [1]. It is therefore evident that the stable electrical double layer is not formed during the present ultra-short pulse application. Since an electric field as high as 2.6-47V cm-1 can be applied in the present work, the lack of formation of the stable electric double layer means that hydrogen ions can be moved faster than in conventional DC electrolysis. These different mechanisms that arise via ultra-short pulse application, leading to the absence of the diffusion layer and the stable electrical double layer, mau open the possibility of high capacity water electrolysis.
# Experimental: In order to examine the possibility of water electrolysis by ultra-short pulses, 3.41 of 1M KOH solution were put in an electrolysis bath. 3.3x9cm2 platinum plates were used as the anode and cathode. The distance between electrodes was set as 3 cm. The solution temperature was kept at 293 +-2 K during the experiment. A conventional DC power supply and an ultra-short pulse power supply were used for comparison. The ultra-short pulse power supply consisted of the IES circuit with a SIThy as shown in Figure1. Ultra-short pulses with a voltage pulse-width of about 300ns, with the secondary peak voltage rangin from 7.9 to 140V were applied to the electrochemical bath with the frequency of 2-25 kHz. The input power was changed by increasing the pulse frequency.
In the IES circuit (Figure1), the gate of the SIThy is connected to the anode through a diode. When the FET (Field Effect Transistor) is switched on, the current through the inductive coil (L1) gradually increases. When the FET is switched off at a certain current level, the current flow is instantly switched off and the inverse voltage Vp1 is induced through the coil (L1). This IES circuit is the simplest and most compact one yet reported for generating ultra-short pulses [6-8].
Fig.1. Ultra-short pulsed power supply circuit for water electrolysis based on the inductive energy storage (IES) circuit [6-7] with a static induction thyristor (SIThy).
In the case of water electrolysis using the above ultra-short pulse power, the water bath electrodes are connected to the secondary reactance L2 as seen in Figure1. The pulsed voltage Vp2 is induced in the secondary reactance L2, synchronized with the pulsed voltage Vp1 as seen in Figure2. In the first stage, when this secondary pulsed voltage is applied to the electrodes in the water bath, the bath acts as a quasi-capacitor since the pulse width is too short for ions in the bath to cause a current through the bath. This gives a very short pulsed current Ip2 in the circuit through the secondary coil (L2). This current is too rapid to be seen in the figure. The water bath is not a real capacitor since all electrons collected at the cathode are transferred to hydrogen ions and high voltage does not remain as in the case of conventional capacitors. After this pulsed voltage had been applied to the electrolysis bath, in the second stage, the current I2 flows through the circuit. This current flows very slowly as seen in the figure with several tens microseconds. Since the application of the pulsed voltage Vp2 was already terminated, this current flow I2 may not be due to electron transfer to hydrogen ions but ion transport in the bath, thus compensating the lack of hydrogen ions in the vicinity of the cathode electrode.
# Results and discussion: The hydrogen generation rate and its efficiency are plotted as a function of the input power between the electrodes in Figure3. In the case of DC power electrolysis, when the applied voltage is increased, the current increases so that hydrogen generation rate increases, but the efficiency compared with the ideal generation rate decreases from 40% at 2.2V to 8% at 12.6V. Here, the ideal generation rate was calculated from thermodynamical data [10], for the thermodynamical energy for hydrogen to be converted to room temperature water. The decrease in efficiency can be explained because an electron with high energy can only reduce one hydrogen ion so that the difference between the applied voltage and the decomposition voltage is dissipated as heat. Since the current itself is also increased by increasing the applied voltage, electrons which are not used for hydrogen reduction are also dissipated as heat.
Contrary to the case of DC power electrolysis, ultra-short power electrolysis shows a quite different behaviour. As seen in Figure3(a), in the case of DC electrolysis, the hydrogen generation rate was not proportional to the input power. It deviates from the ideal line. The hydrogen generation efficiency is calculated as the ratio of the real generation rate to the ideal hydrogen generation rate and it can be seen in Figure3(b) that the efficiency is largely decreased in the case of DC electrolysis. This decrease is mainly because the energy of most electrons is dissipated as heat.
In the case of pulse power, it is seen in Figure3(a) that the hydrogen generation rate is increased as the peak voltage is decreased. It should be noted, however, that the hydrogen generation rate increases as a function of the input power. This behaviour is quite different from the case of DC electrolysis. When the input power is increased by increasing the pulse frequency, the efficiency was not decreased in the case of high peak voltages, and was increased in the case of low peak voltages as seen in Figure3(b). This behaviour is contrary to the case of DC power. This increase of the efficiency for the case of low peak voltage may be because the energy dissipation is decreased since each electron has lower energy and the pulse waveform is sharper for low peak voltages. For these reasons, power can be efficiently consumed for electrolysis. This fact implies that the ultra-short power electrolysis is a promising method in which the power application can be increased even with an increase in electrolysis efficiency.
In the case of DC power, the electric field is always present. The electrical double layer is also present and the diffusion layer always exist. The current flow is therefore determined by the diffusion of ions with a driving force of ion concentration difference. When the applied voltage is increased, the efficiency decreases. In the cse of DC power, the power applicable for a certain volume of the electrolysis bath is therefore limited.
Fig.2. A typical example of pulse waveforms for the first and second stages. In the first stage, an ultra-short pulse with the width of about 300ns is applied. In the second stage, the current flows slowly.
Fig.3. Hydrogen generation rate (a) and its efficiency (b) as a function of the input power. In the case of pulsed power, various circuits with different voltage (Vp2), current (I2max) and frequency ((i)-(iv)) have been compared. The input power is the integration of the secondary voltage and current multiplied by the frequency. The ideal line was calculated from the thermodynamical energy for hydrogen to be converted to room temperature water. Hydrogen generation efficiencies in (b) were calculated as the hydrogen generation rate divided by the ideal hydrogen generation rate at the same input power.
In the case of ultra-short pulsed power, the electric field is applied for only a very short time less than several microseconds which is much shorter than the time necessary for the formation of the constant electric double layer. By the application of the ultra-short pulse, electrons are collected on the surface of the cathode electrode as in a capacitor. The electrons gathered however are quickly transferred to hydrogen ions for hydrogen generation so that electrons do not remain in the electrode as in a conventional capacitor. After this electron transfer, the current I2 flows slowly as shown in Figure2, probably due to the ion diffusion in the electrolysis bath.
From the above considerations, it can be concluded that the electrolysis mechanism for ultra-short pulse power is very different from that of DC electrolysis. DC electrolysis is based on electrical double layer formation and is a diffusion-limited process, while ultra-short pulse power electrolysis is based on the strong electric field application and the electron transfer limited process. This difference seems to be very important for the practical and industrial application of ultra-short power electrolysis since the electrolysis power can be increased without decreasing the efficiency.
# Conclusion: We have shown in this preliminary work how an ultra-short power supply, consisting of a SIThy and an IES circuit, can be applied to water electrolysis for hydrogen generation. It has been found that an ultra-short pulse of about 300ns could generate hydrogen gas. It was also found that power could be increased without decreasing the electrolysis efficiency. The present results point to the possibility that water electrolysis by ultra-short pulsed power occurs under the electron transfer-rate limiting mechanism, which is different from the conventional diffusion-limiting mechanism in DC power electrolysis.
# Ackonledgements: We thanks Messrs S. Ohno and T. Inaba for their encouragement of this work, Mrs K. Matsuhiro, Y. Imanishi and S. Tange for their helpful discussion, and Mr M. Imaeda for his experimental help.
« Last Edit: August 14, 2012, 00:50:44 am by Steve »
« Reply #3 on: August 14, 2012, 08:57:59 am »
Please reassume what you want ask about.. isn't clear  .. without figures isn't possible understand.. please indicate link or post document. Regards
« Reply #4 on: September 01, 2012, 16:09:46 pm »
Your explaination is correct in part.. for obtain REAL BROWN GAS you need an serie cell that support pressure and an adaptive/resonance AC power source low voltage, all in one. Regards
