Author Topic: RVIC Wiring Diagram  (Read 4544 times)
RVIC Wiring Diagram
« on: May 13, 2011, 01:37:43 am »
A requested diagram...
  • Jesus Christ is Lord! www.stansdream.com
    • Stan's Dream
Re: RVIC Wiring Diagram
« Reply #1 on: May 13, 2011, 01:42:21 am »
Wow, thanks for this diagram.
Is the alternator rewound at all or just deregulated?
About how many amps did you pull for the whole circuit?
I am making changes as we speak and am going to try some different setups...
« Reply #2 on: May 13, 2011, 02:01:17 am »
I have tried a few different rewound stators, but, the stock one it came with worked best. I was pulling about 25A through the cell with an input of about 2A from the variable transformer.
    • Stan's Dream
« Reply #3 on: May 13, 2011, 03:15:31 am »
Wow! That is quite a lot, but also a lot of production!
One last question regarding the alternator layout - in the diagram, you show a central point where the three phases meet.
What is this? Is it a center tap created when you wound the alternator windings or is it a stock connection?
I do understand the stator winding is not shown, as it is connected to the control box.
Is there any pulse applied to the stator, or is it Meyer's box schematic?
Thanks - this will definitely help those desiring to replicate this!
« Reply #4 on: May 13, 2011, 15:50:14 pm »
The center tap sort of thing where the 3 phases are tied together is the way it comes stock and usually called "neutral". I just used it as a connection point. I don't know what I was thinking at the time or why I did it that way. The rotor can be considered as being pulsed with fully rectified AC @ 60Hz = 120Hz DC pulses.
« Reply #5 on: May 13, 2011, 19:23:18 pm »
stan never shows that circuit, not with full-wave like that, look in the 661 patent for the real circuit, 200 volt output he describes
« Reply #6 on: May 13, 2011, 21:02:57 pm »
What circuit are you talking about Donald? The tubular demo cell?
« Reply #7 on: May 13, 2011, 21:29:46 pm »
The one I referenced specifically in the 661 patent with 200 volt output may be of interest... It has 6 diodes, but not configured like you show. The only other 6 diode diagram is the first of figure 8-11 in the tech brief, while the second of figure 8-11 has 9 diodes, and the one in the independent report has 3 diodes.
