Who built the gated pulse gen like in the patent or like Tony and worked?I tried bouth crkts on breadboard and pcb and none of them worked....
Quote from: Login to see usernames on December 10, 2012, 17:46:13 pmWho built the gated pulse gen like in the patent or like Tony and worked?I tried bouth crkts on breadboard and pcb and none of them worked....Did you hook it up to a powersupply? Just kidding......Do you see a squarewave on yr scope, without having a load to the circuit?Steve
Quote from: Login to see usernames on December 10, 2012, 17:46:13 pmWho built the gated pulse gen like in the patent or like Tony and worked?I tried bouth crkts on breadboard and pcb and none of them worked....http://www.ionizationx.com/index.php/topic,2523.msg23643.html#msg23643Check if you have version 1 pcb of Tony.Regards
The gate is only a mean for controlling gas output, in later design actually it is probably substituted by the injectors signal... think about it...
