Author Topic: Gated Pulse Frequency Generator Schematic  (Read 35395 times)
Re: Gated Pulse Frequency Generator Schematic
« Reply #56 on: April 04, 2011, 10:08:55 am »
@Ali
« Reply #57 on: April 04, 2011, 11:16:07 am »
@ All
Is the Control Circuits group figures 2 thru 12 supposed to also work on Stan's later development where the buggy ran on Injectors and a Gas Processor only ( NO resonant cavity) and the new slotted stacked bobbin 6-1 VIC for each injector?
wondering if this circuitry was only designed for the U-I core VIC we have been watching Tony Build???
What Stan said in one of his videos is that all the parts could be miniaturized to a few chips. I assume that the separate circuits could be programmed in a micro-controller system on chip at the end.
The Injectors and Gas Processor are also resonant cavities but at a different scale and parameters as the U-I core used for the 10 WFC type resonant cavity.
The resonant cavity is the space (gap) between two electrodes where longitudinal waves are generated and "Resonant Action" occurs.
br,
Webmug
« Reply #58 on: April 04, 2011, 20:40:53 pm »
Webmug,
Your right about the microcontroller. It's mentioned in the WFC News Release issue no 10. There is a pic of it in that news release. It states that the chip is able to perform 1.6 million logic functions per second. I think I actutally have a picture of his final boards which shows the microcontroller on it.
If you don't have that news release it on tony's site, globalkast.org under documentation.
Thanks Tony!
« Reply #59 on: April 05, 2011, 11:18:14 am »
Allthough i have been mostly observing, reading and learning on this forum for the last months, i also have started to design, simulate and build my own wfc. Since i have a background in electronics and computer science i decided to base my system on a microchip PIC processor. I think that by using  a micro processor you not only reduce the part count it also greatly improves the possibilities to test and debug your wfc since i am able to change parameters or even the entire configuration with in system programing in very little time from software instead of changing entire electronic circuits. I hope to show some early results soon ..... (why doesn't a day have more than 24 hours  :P )
« Reply #60 on: April 05, 2011, 13:26:00 pm »
That's great Sharky, looking forward for your results.
What is your solution for a PLL function in the controller with electronics and computer science background?
Are you clocking the PIC clock dynamically or do you use Software PLL (ADC/DAC) solution. Should be (0Hz - 20kHz) range.
My idea is to build a 12bit SPLL using a ADC or PULSE counter to generate GATED PULSE signal from the DAC on a STM32 SoC.
I don't know if a microcontroller could do 0.01Hz or 0.001Hz steps accuracy for resonance PULSE adjustments.
Maybe a FPGA chip could be handy?
It would be great if you also use a SPPL or have other solutions.
br,
Webmug
« Last Edit: April 05, 2011, 14:17:16 pm by webmug »
« Reply #61 on: April 06, 2011, 02:18:44 am »
Well I completed the system and have been testing it for the past couple days. I haven't been about to generator high voltages with the transformer. This could maybe be to the cores that Im using, maybe I need ferrite cores instead of powder iron. I'll have to see if i can get a hold of some of these cores!
    • Stan's Dream
« Reply #62 on: April 06, 2011, 14:10:47 pm »
Wow, Tony, you are really making progress.
I have finished the 8XA, and am tweaking it.
Do you plan on having the schematics and nfo for the resonant scanning circuit on your site at some point?
Kudos to all!
Praise the Lord and pass the ammunition!
« Reply #63 on: April 06, 2011, 15:06:47 pm »
You could try OG laminations, so you can cut the way you want it (keep in mind the orientation). Would be difficult to get a ferrite with the specific size of your bobbins, otherwise you would need more bobbins.
