Author Topic: Gated Frequency Generator  (Read 16567 times)
Re: Gated Frequency Generator
« Reply #8 on: March 25, 2011, 21:31:46 pm »
The gate pulse is super imposed over the resonant frequency to form the Pulse Train which will make it fully adjustable. The gate pulse can also be used to extract the electrons from the water during OFF time so that when theres no pulses being applied to the cell the EEC will be active and will pull the free electrons out of the water. Its also used to increase the charged voltage in the cell. The Pulse Train be comes widen while pulse off-time width becomes smaller. Conversely, opposite pulse shaping occurs when its calibrated in revers order.
« Reply #9 on: March 25, 2011, 21:36:20 pm »
So Don are you referring to the Injector setup or Resonant Cavity setup? The reason I ask is cuz in the Injector setup, the gate can be used as a trigger for the injector gate to allow water into the injector.
« Reply #10 on: March 25, 2011, 21:46:11 pm »
The answer I'm looking for is for the resonance cavity.The EEC is not the reason for the gating.Alot of what is said is true on what the gating contributes to,but still is not the primary reason for it.
Keep working on it,
« Reply #11 on: March 25, 2011, 22:02:29 pm »
A gate pulse controls the number of pulses produced by the resonant frequency generator sent to the primary coil during a period determined by the gate frequency of the second pulse generator. The gate can be connected to a pressure sensor that can be placed in the Resonant Cavity which also includes a gas outlet. The gas pressure sensor is operatively connected to the circuit to determine the rate of gas production with respect to ambient gas pressure in the water capacitor enclosure.
When the maximum gas pressure is reached in the resonant cavity, the sensor will send a signal to the gated pulse generator which will stop the pulses from being applied to the primary of the transformer until the pressure in the resonant cavity drops to a safe point.
Heres the logics for the circuit.
(http://www.globalkast.com/images/tonywoodside/Fig.6_logics.PNG)
« Last Edit: March 25, 2011, 23:46:31 pm by TonyWoodside »
« Reply #12 on: March 25, 2011, 23:28:11 pm »
Yes Tony all of that is a funtion from the gate signal,but it's still not the primary purpose of the gating.What your talking about uses the gating pulses,but it's not the main funtion.
What would you need a manual adjusted frequency for? We're not looking for how to make the frequency,we all know how to do that.We're looking for the reason we need gating.
Look at my other question about LC Resonance.
« Reply #13 on: March 25, 2011, 23:39:44 pm »
The only thing I can think of right now is that the gate pulse is used to promote the step-charging effect in the cell. it also can control the charge/discharge rate of the cell. There may also be a need to allow a definite relaxation time after each pulse, to increase the period in which the ionized charges may recombine and hydrogen and oxygen may be collected.
« Last Edit: March 26, 2011, 00:03:08 am by TonyWoodside »
« Reply #14 on: March 25, 2011, 23:52:26 pm »
The gas pedal Don!?? hehe
« Reply #15 on: March 25, 2011, 23:54:04 pm »
The cell should work like a pump according to Stan, This means that for each pulse train there must be a relaxation period for new water to enter the resonant cavity. This is evident by the discharge time in the graphic.
You dont want it arcing without water in there.
