Author Topic: Gated Frequency Generator  (Read 16572 times)
Re: Gated Frequency Generator
« Reply #24 on: March 26, 2011, 02:28:50 am »
Donald, you just hit on it!! Do you know what it is you just said? Forget about the 94 second statement,that doesn't matter.
when you match the pulses to the movement of the particles between the plates to match their motion,
What does that mean?
So what would you use the gating frequency for?
« Reply #25 on: March 26, 2011, 02:29:19 am »
one more thing, it also allows u to control the amount of high voltages being made in the cell.
« Reply #26 on: March 26, 2011, 02:38:20 am »
well, i have a lot of things i'm thinking about and not sure exactly what you are going for, as the correct picture
i might venture that the high pulse frequency gets you electrical resonance of the VIC which turns into a huge impedance to current flow, then the gating is applying these current restricted voltage pulses to the cell at a frequency to match the water movement between the plates
i have been trying to figure out a way to calculate the frequency for the motion of the water, but so far no luck, but like stan says in 661, it is more readily determined empirically, so maybe this is why he has manual tuning on it
« Reply #27 on: March 26, 2011, 02:48:54 am »
So its used to match the number of Resonant pulses to the wavelength or movement of the water molecule by manually adjusting the gate?
« Reply #28 on: March 26, 2011, 02:53:27 am »
Donald you just said the magic words right there.
This is how Stan does it.
First we find LC Resonance with the PLL to lock onto and hold.This creates the high voltage that Stan talks about that is needed.
Then we take the high voltage and use the gating frequency to tune into the WATERS MECHANICAL RESONANCE !!!
The Gating Frequency is used to tune into the water that is between the tubes and make it resonate !!!
We are turning on and off the high voltage with the gating frequency to match the waters resonance between the tubes.
This is the mechanical resonance of the water,not LC resonance !!
Then we can use the duty cycle on the gating to control the gas production.
Once the mechanical resonance is set,you shouldn't need to change the frequency of the gating signal.It won't change once found.
Can we all see it now?
It's that simple and Stan has that in his papers.
« Reply #29 on: March 26, 2011, 02:57:36 am »
ahhh makes a lot more sense now, very interesting!!!
« Reply #30 on: March 26, 2011, 03:05:09 am »
so the PLL finds the LC resonance then u use the variable frequency generator to tune into the waters frequency and once you find this u should make gas and then u can control the amount of gas production by varying the duty cycle. sounds so simple
« Reply #31 on: March 26, 2011, 03:09:45 am »
(http://img.photobucket.com/albums/v81/bigbuba/Picture41-2.png)
