Author Topic: Resonance WFC measurements  (Read 50520 times)
Re: Resonance WFC measurements
« Reply #40 on: June 14, 2011, 19:08:41 pm »
I'm talking about the Resonance WFC cell driver circuit, not a 8XA coil.
To make it more clearer see fig below.
Br,
Webmug
« Reply #41 on: June 14, 2011, 23:21:46 pm »
gotcha, thanks for circuit diagram, I may try it anyway into my 3 inch, 1/2 mm gap tubes....  after my bifilar toroid
« Reply #42 on: February 22, 2012, 14:19:25 pm »
@Dave, All,
This is what I measured on a 10kV 1nf capacitor.
Could be the above 0V voltage that brings up the "above ground level".
http://www.ionizationx.com/index.php/topic,1305.msg22180.html#msg22180
http://www.ionizationx.com/index.php/topic,1305.msg22161.html#msg22161
PULSE TRANSFORMER The typical pulse transformer operates in an “unipolar” mode ( flux density may meet but does not cross zero ).
http://www.ionizationx.com/index.php/topic,1934.msg20298.html#msg20298
Br,
Webmug
« Last Edit: February 22, 2012, 22:44:22 pm by webmug »
« Reply #43 on: February 22, 2012, 19:44:24 pm »
looks pretty good to me. So 500 volts or so is the highest you've gotten?
Anything special you did to get your singnal inverted like that?
« Reply #44 on: February 22, 2012, 21:41:46 pm »
My chokes are not tuned, the voltage amplitudes are not equal but have opposite voltages when I vary the pulse frequency. I can not tune it with the pulse and gate signals. Chokes are not matched!
I tested this on a 10kV 1nf HV capacitor, when I use my wfc this waveform is not there. So the cell specs are very important to minimize leakage, I think...
Br,
Webmug
« Reply #45 on: February 22, 2012, 21:54:15 pm »
Ok I see, I can get the correct waveform when I don't have the cell hooked up. The closer we get to what stan had the better at this point. If there is an unknown variable maybe we can stumble across it.
« Reply #46 on: February 22, 2012, 22:35:27 pm »
Just curious, do you get the desired waveform from the cell being dry or without water in it?
« Reply #47 on: February 22, 2012, 22:42:01 pm »
Waveform above from 1nf HV 10kV capacitor.
Cell was submerged in tap-water no waveform.
Br,
Webmug
