Author Topic: Resonance WFC measurements  (Read 50495 times)
Re: Resonance WFC measurements
« Reply #112 on: March 21, 2012, 02:17:21 am »
waterfreak,
copper wires is also resistive wire.It has resistence too.It doesn't mean you need stainless wire.
« Reply #113 on: March 21, 2012, 13:43:14 pm »
Thanks for helping to keep us on track.
Perhaps Stan is just trying to throw us off by stating it is resistive wire?...
« Reply #114 on: March 24, 2012, 16:10:03 pm »
There is much to learn on tesla stuff. I found a book recently where he shows many simple inventions with a great deal of generosity. I found this book because it was cited by another inventor. I personally believe stan uses some of this to accomplish the unipolar pulsing.
good luck
« Reply #115 on: March 25, 2012, 04:09:07 am »
I'm guessing your talking about the tesla colorado notes book?
« Reply #116 on: March 25, 2012, 10:18:59 am »
This is a video I made 2 days ago when I was running some tests with my single cell, VIC Transformer, and VIC Circuit. My scope was connected between the diode and L1 Choke like Stephen Meyer's shows in his patent and the waveform is pretty much a perfect match as his.
http://www.youtube.com/watch?v=Wr3viEo2pVI
I have also added an attachment which is a picture of the signal across the cell.
« Reply #117 on: March 25, 2012, 18:44:48 pm »
"The inventions research and writing..."
« Reply #118 on: March 25, 2012, 20:23:52 pm »
Seb, Tony:
I'm guessing that we've been getting this waveform from various 9ax, 8xa and similar VICs built by this and other groups for some time now.  Now where to?
My observations show that by adjusting the resistance to ground at the negative choke and plate it appears to only reduce ringing voltages yet has no discernable effect on gas production.  For example, my ringing voltages PTP are 2000v with anything over 80k ohm and can be drawn down to 100v ptp ringing with zero resistance to ground via a 100k pot.
kb
« Reply #119 on: March 26, 2012, 04:50:48 am »
Tony, that is an interesting vid, and as you said it looks just like the waveforms shown on Steve's patent.
Is this the same setup that you have been using?   Is there any gas being produced?
From what I can see there is a high frequency ringing between each pulse....Could be a resonance between parasitic componnets of the coils or even the capacitance of the diode. I wonder how much higher the freq is than the driving freq, and if it's ringing or harmonics showing up?
